Message 1 of 20
Multiple dropped connection every evening (CWMP: session closed due to error: No response)
Hi,
Been having issues with my connection dropping out apx every 45 mins from 16:00 to 22:00 every eveing for the last two weeks.
I tried an asus vdsl router and that didnt work
This is really annoying as it interupts streaming and online games etc
HH5 is back in now.
Line test for noise seems ok
Getting perfect speeds even in the evening
Any help would be greatly appreciated
Stephen
1. Product name:BT Home Hub
2. Serial number:+068343+NQ60805164
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 23/06/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 16:10:12
6. Data rate:9995 / 54995
7. Maximum data rate:18545 / 58685
8. Noise margin:12.1 / 8.1
9. Line attenuation:21.7 / 18.0
10. Signal attenuation:21.5 / 17.8
11. Data sent/received:6.4 GB / 112.1 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-6G8W
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-6G8W
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:90:72:82:87:e2:e8
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
19 REPLIES 19
Message 2 of 20
Re: Multiple dropped connection every evening (CWMP: session closed due to error: No response)
Log for 1 day
Disconnects that evening 😞
12:40:12, 27 Dec. (410465.700000) CWMP: session completed successfully
12:40:11, 27 Dec. (410465.350000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
12:40:10, 27 Dec. (410464.350000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
12:40:10, 27 Dec. (410464.340000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
12:40:10, 27 Dec. (410463.850000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
12:40:08, 27 Dec. (410462.000000) CWMP: session completed successfully
12:40:08, 27 Dec. (410461.830000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
12:40:06, 27 Dec. (410460.240000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
12:40:06, 27 Dec. (410460.230000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
12:40:06, 27 Dec. (410459.760000) CWMP: Initializing transaction for event code 2 PERIODIC
21:17:09, 26 Dec. (355083.160000) CWMP: session completed successfully
21:17:09, 26 Dec. (355082.970000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
21:16:59, 26 Dec. (355072.680000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:16:59, 26 Dec. (355072.670000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:16:29, 26 Dec. (355043.000000) CWMP: session closed due to error: No response
21:16:25, 26 Dec. (355038.650000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:16:25, 26 Dec. (355038.640000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:15:50, 26 Dec. (355003.770000) CWMP: session closed due to error: No response
21:15:48, 26 Dec. (355001.470000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:15:48, 26 Dec. (355001.460000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:15:47, 26 Dec. (355000.980000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
20:07:02, 26 Dec. (350875.840000) CWMP: session completed successfully
20:07:02, 26 Dec. (350875.660000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
20:06:51, 26 Dec. (350864.760000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:06:51, 26 Dec. (350864.750000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:06:22, 26 Dec. (350836.140000) CWMP: session closed due to error: No response
20:06:18, 26 Dec. (350831.640000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:06:18, 26 Dec. (350831.640000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:05:44, 26 Dec. (350797.500000) CWMP: session closed due to error: No response
20:05:41, 26 Dec. (350794.790000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:05:41, 26 Dec. (350794.780000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:05:40, 26 Dec. (350794.300000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
18:33:09, 26 Dec. (345243.060000) CWMP: session completed successfully
18:33:09, 26 Dec. (345242.710000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:32:45, 26 Dec. (345219.380000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:32:45, 26 Dec. (345219.370000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:31:14, 26 Dec. (345128.000000) CWMP: session closed due to error: No response
18:31:14, 26 Dec. (345127.490000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:31:14, 26 Dec. (345127.480000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:30:43, 26 Dec. (345097.030000) CWMP: session closed due to error: No response
18:30:43, 26 Dec. (345096.680000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:30:43, 26 Dec. (345096.670000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:30:42, 26 Dec. (345096.190000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
18:09:44, 26 Dec. (343837.490000) CWMP: session completed successfully
18:09:37, 26 Dec. (343830.760000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:09:16, 26 Dec. (343809.630000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:09:16, 26 Dec. (343809.630000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:08:20, 26 Dec. (343753.520000) CWMP: session closed due to error: No response
18:08:19, 26 Dec. (343753.350000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:08:19, 26 Dec. (343753.340000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:07:49, 26 Dec. (343722.890000) CWMP: session closed due to error: No response
18:07:48, 26 Dec. (343722.360000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:07:48, 26 Dec. (343722.350000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:07:48, 26 Dec. (343721.880000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
17:23:00, 26 Dec. (341033.700000) CWMP: session completed successfully
17:23:00, 26 Dec. (341033.530000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
17:22:51, 26 Dec. (341024.570000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:22:51, 26 Dec. (341024.560000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:22:25, 26 Dec. (340999.370000) CWMP: session closed due to error: No response
17:22:20, 26 Dec. (340994.330000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:22:20, 26 Dec. (340994.330000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:21:44, 26 Dec. (340958.410000) CWMP: session closed due to error: No response
17:21:44, 26 Dec. (340957.830000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:21:44, 26 Dec. (340957.820000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:21:43, 26 Dec. (340957.350000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
16:32:12, 26 Dec. (337987.360000) CWMP: session completed successfully
16:32:11, 26 Dec. (337987.180000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
16:32:02, 26 Dec. (337977.550000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:32:02, 26 Dec. (337977.540000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
16:31:33, 26 Dec. (337948.700000) CWMP: session closed due to error: No response
16:31:27, 26 Dec. (337943.110000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:31:27, 26 Dec. (337943.100000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
16:30:51, 26 Dec. (337907.000000) CWMP: session closed due to error: No response
Recognised Expert
Message 3 of 20
CWMP (CPE WAN Management Protocol) is a protocol used by service providers to manage the router i.e., the Home Hub in this case. These messages indicate the Hub was trying to connect to the ACS (Auto Configuration Server) and could not for some reason. It does not indicate the broadband disconnecting.
Do you see anything in the log for PPP or WAN events?
Regards
Message 4 of 20
Hi smf22
Thanks for the info!
here is the wan log
21:16:41, 26 Dec.
(355054.530000) WAN operating mode is VDSL
21:16:41, 26 Dec.(355054.530000) Last WAN operating mode was VDSL
21:16:38, 26 Dec.(355052.010000) PPP IPCP Receive Configuration ACK
21:16:38, 26 Dec.(355052.000000) PPP IPCP Send Configuration Request
21:16:38, 26 Dec.(355052.000000) PPP IPCP Receive Configuration NAK
21:16:38, 26 Dec.(355051.880000) PPP IPCP Send Configuration ACK
21:16:38, 26 Dec.(355051.880000) PPP IPCP Receive Configuration Request
21:16:38, 26 Dec.(355051.630000) PPP IPCP Send Configuration Request
21:16:36, 26 Dec.(355049.520000) PPPoE is up -​ Down Rate=54995000Kbps, Up Rate=9995000Kbps; SNR Margin Down=8.1dB, Up=12.2dB
21:16:36, 26 Dec.(355049.510000) CHAP authentication successful
21:16:35, 26 Dec.(355049.420000) CHAP Receive Challenge
21:16:35, 26 Dec.(355049.420000) Starting CHAP authentication with peer
21:16:35, 26 Dec.(355049.420000) PPP LCP Receive Configuration ACK
21:16:35, 26 Dec.(355049.420000) PPP LCP Send Configuration Request
21:16:35, 26 Dec.(355049.420000) PPP LCP Receive Configuration Reject
21:16:35, 26 Dec.(355049.410000) PPP LCP Send Configuration ACK
21:16:35, 26 Dec.(355049.410000) PPP LCP Receive Configuration Request
21:16:35, 26 Dec.(355049.410000) PPP LCP Send Configuration Request
21:16:20, 26 Dec.(355033.640000) PTM over DSL is up
21:15:39, 26 Dec.(354993.330000) PTM over DSL is down after 69 minutes uptime
21:15:39, 26 Dec.(354993.310000) PPPoE is down after 69 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
21:15:33, 26 Dec.(354987.190000) PPP LCP Send Termination Request [User request]
20:06:33, 26 Dec.(350846.890000) WAN operating mode is VDSL
20:06:33, 26 Dec.(350846.890000) Last WAN operating mode was VDSL
20:06:30, 26 Dec.(350844.370000) PPP IPCP Receive Configuration ACK
20:06:30, 26 Dec.(350844.370000) PPP IPCP Send Configuration Request
20:06:30, 26 Dec.(350844.360000) PPP IPCP Receive Configuration NAK
20:06:30, 26 Dec.(350844.360000) PPP IPCP Send Configuration ACK
20:06:30, 26 Dec.(350844.360000) PPP IPCP Receive Configuration Request
20:06:30, 26 Dec.(350844.240000) PPP IPCP Send Configuration Request
20:06:28, 26 Dec.(350842.140000) PPPoE is up -​ Down Rate=54995000Kbps, Up Rate=9995000Kbps; SNR Margin Down=8.3dB, Up=12.0dB
20:06:28, 26 Dec.(350842.130000) CHAP authentication successful
20:06:28, 26 Dec.(350842.070000) CHAP Receive Challenge
20:06:28, 26 Dec.(350842.070000) Starting CHAP authentication with peer
20:06:28, 26 Dec.(350842.070000) PPP LCP Receive Configuration ACK
20:06:28, 26 Dec.(350842.060000) PPP LCP Send Configuration Request
20:06:28, 26 Dec.(350842.060000) PPP LCP Receive Configuration Reject
20:06:28, 26 Dec.(350842.060000) PPP LCP Send Configuration ACK
20:06:28, 26 Dec.(350842.060000) PPP LCP Receive Configuration Request
20:06:13, 26 Dec.(350826.520000) PTM over DSL is up
20:05:32, 26 Dec.(350786.340000) PTM over DSL is down after 94 minutes uptime
20:05:32, 26 Dec.(350786.340000) PPPoE is down after 93 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
20:05:26, 26 Dec.(350780.270000) PPP LCP Send Termination Request [User request]
18:32:26, 26 Dec.(345200.360000) WAN operating mode is VDSL
18:32:26, 26 Dec.(345200.360000) Last WAN operating mode was VDSL
18:32:24, 26 Dec.(345197.810000) PPP IPCP Receive Configuration ACK
18:32:24, 26 Dec.(345197.810000) PPP IPCP Send Configuration ACK
18:32:24, 26 Dec.(345197.810000) PPP IPCP Receive Configuration Request
18:32:24, 26 Dec.(345197.640000) PPP IPCP Send Configuration Request
18:32:24, 26 Dec.(345197.640000) PPP IPCP Receive Configuration NAK
18:32:24, 26 Dec.(345197.550000) PPP IPCP Send Configuration ACK
18:32:24, 26 Dec.(345197.550000) PPP IPCP Receive Configuration Request
18:32:23, 26 Dec.(345196.730000) PPP IPCP Send Configuration Request
18:32:21, 26 Dec.(345194.590000) PPPoE is up -​ Down Rate=54995000Kbps, Up Rate=9995000Kbps; SNR Margin Down=8.3dB, Up=12.0dB
18:32:21, 26 Dec.(345194.570000) CHAP authentication successful
18:32:20, 26 Dec.(345194.440000) CHAP Receive Challenge
18:32:20, 26 Dec.(345194.440000) Starting CHAP authentication with peer
18:32:20, 26 Dec.(345194.430000) PPP LCP Receive Configuration ACK
18:32:20, 26 Dec.(345194.430000) PPP LCP Send Configuration Request
18:32:20, 26 Dec.(345194.430000) PPP LCP Receive Configuration Reject
18:32:20, 26 Dec.(345194.430000) PPP LCP Send Configuration ACK
18:32:20, 26 Dec.(345194.430000) PPP LCP Receive Configuration Request
18:31:40, 26 Dec.(345154.220000) PPP LCP Send Termination Request [PPPoE PADT received]
18:31:40, 26 Dec.(345154.200000) PPP LCP Send Configuration ACK
18:31:40, 26 Dec.(345154.200000) PPP LCP Send Configuration Request
18:31:40, 26 Dec.(345154.200000) PPP LCP Receive Configuration Request
18:31:40, 26 Dec.(345154.190000) Starting CHAP authentication with peer
18:31:40, 26 Dec.(345154.190000) PPP LCP Receive Configuration ACK
18:31:39, 26 Dec.(345153.390000) PPP LCP Send Configuration ACK
18:31:39, 26 Dec.(345153.390000) PPP LCP Receive Configuration Request
18:31:37, 26 Dec.(345151.230000) PPP LCP Send Configuration Request
18:31:37, 26 Dec.(345151.230000) PPP LCP Receive Configuration Reject
18:31:36, 26 Dec.(345150.450000) PPP LCP Send Configuration ACK
18:31:36, 26 Dec.(345150.450000) PPP LCP Receive Configuration Request
18:31:36, 26 Dec.(345150.030000) PPP LCP Send Configuration Request
18:31:18, 26 Dec.(345132.270000) PTM over DSL is up
18:30:34, 26 Dec.
(345087.900000) PTM over DSL is down after 22 minutes uptime
Recognised Expert
Message 5 of 20
Interesting that the PPP messages are 'PPP LCP Send Termination Request' which would appear as if it's the hub that's requesting the connection be terminated. It may do this if it doesn't receive the 'heart beat' packet that PPP uses, but I thought there was normally a 'timeout' message if that was the case.
If this has been happening in the evening over the last few weeks could it be that there are Christmas tree lights turned on during this time? The power supplies that come with tree lights are possibly not the best and very likely emit electromagnetic interference that could affect your broadband.
Regards
Message 6 of 20
The 'PPP LCP Send Termination Request'  has been a long standing problem with Home Hubs that I don't believe has ever been fully explained or resolved.
Sage
Message 7 of 20
@EnkayeWhat model Asus are you trying to use? If it is a VDSL modem/router it should work if configured correctly.
Message 8 of 20
Hi pippincp
It was an ASUS DSL-AC68U AC1900 Dual-Band Wireless VDSL/ADSL 2+ Gigabit Modem Router
(latest firmware)
I had a terrible time setting it up, wouldnt recognise it was connected to the phone jack. had to create profile then retry the wizard.
When I got it working it kept giving warnings on the info screen saying the connection is unstable and it would auto adjust.
Google helped with turing bitswap off then those warnings went.
In the evening it went all funny, no discon errors in the logs but no connection....
I did some reading up on that modem and seems others have had problems with also.
I may try another router or just a modem but am unsure what to try?
Sage
Message 9 of 20
You might want to look at THIS thread.
Message 10 of 20
I may try with those settings again - was afraid it was going to throttle my line the way it was...
