Message 1 of 6
Multiple router and networks from one telephone line
Hello, I currently have one BT router which pugs into my telephone line that provides internet to the rest of my house. I have another telephone line socket in another room, could I put another router plugged into that and provide a secondary network (or at least an alternative ethernet connection) from the same plan. And would the router have too be BT?
5 REPLIES 5
Message 2 of 6
Re: Multiple router and networks from one telephone line
You can not run two routers of the one connection.
Message 3 of 6
Would there be any way I could have an alternative ethernet connection without having to feed it all the way round my house from where my router currently is?
Message 4 of 6
You could buy power line adaptors and use them.
See link
BT Broadband Extender Flex 600 Kit (084285) | BT Shop
You do not need to use BT ones and you can get cheaper ones if you shop around.
Message 5 of 6
I've heard you can't open ports with those. Or is that unaffected?
Message 6 of 6
No idea where you heard that from, powerline adapters just use your mains wiring as an Ethernet cable effectively.
TP Link have a good range https://www.tp-link.com/uk/home-networking/powerline/
