bringbackmono
Message 1 of 2
My BT App.......Speedtest
Speedtest via the App is useless. Starts to work then asks you check if your hub is switched on?......If your hub wasn't switched on then you couldn't have accessed the App in the first place......major bug that needs sorting out.
1 REPLY 1
paulo1980
Message 2 of 2
Re: My BT App.......Speedtest
you could have been connected to BT Wifi hotspot just saying...........................
