sabinelb
Message 1 of 8
My BT infinity
Another windy and rainy day, and as ever in those conditions, my BT Infinity coverage has been interrupting all day long. From blue to red to green and blue....... I stopped counting at 35 interruptions in the space of 2 hours.
I did not phone BT today. I have actually given up doing so after my last complaint, through the official complaint department, in writing led to a flurry of emails telling me that it would be solved followed by total silence.
I have reported this fault at least 5 times  over the past 2 years. This starts with an endless wait (20 minutes+) to get connected to a human voice, followed by the now well practised checking of all the bits and bobs, wires, etc before it becomes quite clear that an Engineer will have to call. This usually happens the same week and low and behold everything is deemed ok within my home. Along the years, to be fair, work has been carried out on the line further down the road with no improvement whatsoever.
And so it goes.
I am writing this because I have had enough of this and feel totally powerless at finding a solution to it at this point. I would welcome any suggestions to solve this issue once and for all. I refuse to have to go through the same merry go round again for nothing.
Thank you
7 REPLIES 7
imjolly
Message 2 of 8
Re: My BT infinity
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
are you using the test socket with a new filter or do you have an SSFP?
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
sabinelb
Message 3 of 8
Re: My BT infinity
Thank you for your reply Imjolly
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12:
1. Product name: BT Home Hub
2. Serial number: +068343+NQ41109254
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 10/07/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 01:04:04
6. Data rate: 4999 / 31008
7. Maximum data rate: 6763 / 34356
8. Noise margin: 7.4 / 7.4
9. Line attenuation: 29.9 / 27.5
10. Signal attenuation: 29.9 / 24.9
11. Data sent/received: 7.7 MB / 145.7 MB
12. Broadband username: bthomehub@btbroadband.com
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester:
Broadband speed test results:
Upload: 4.27
Ping: 43.75
  1. Best Effort Test: -provides background information.
Download Speed
 29.7 Mbps
0 Mbps 30.01 Mbps
Max Achievable Speed
Download speed achieved during the test was - 29.7 Mbps
 For your connection, the acceptable range of speeds is  20 Mbps-30.01 Mbps .
 Additional Information:
 IP Profile for your line is - 30.01 Mbps
  1. Upstream Test: -provides background information.
Upload Speed
 4.27 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 4.27Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
The last Engineer changed filter I believe with no improvement
no significant noise on the line, but there is no wind today....
Constant on event log yesterday:
( 986.740000) PTM over DSL is down after 2 minutes uptime
( 982.020000) PPPoE is down after 1 minutes uptime [Disconnected]
1315.400000) PTM over DSL is down after 3 minutes uptime
( 1315.390000) PPPoE is down after 2 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
Today: hub light is blue but with constant dropping of the wifi
Much appreciated
Sabine
imjolly
Message 4 of 8
Re: My BT infinity
your connection time is currently 1hr+ with noise margin slightly above normal 6db at 7.4db  your connection speed is just below attainable and better that top estimate from the dslchecker.  download/upload speed consistent with connection speeds
if your wifi is dropping
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
 try changing channels
you can try downloading inssider3 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
inssider3.1.2.1
sabinelb
Message 5 of 8
Re: My BT infinity
Thank you for your response as it will help with the dropping signal
Smart set up is off
What should I do about performance in bad weather though? I can barely use broadband on a bad day, as it goes down every time the wind blows.
imjolly
Message 6 of 8
Re: My BT infinity
repost stats when weather is causing a problem
DavidM
Moderator
Moderator
Message 7 of 8
Re: My BT infinity
Hi @sabinelb and thanks for posting.
As @imjolly has mentioned if you can post your stats when the problem is happening we'll step in and lend a hand at that point.
Cheers
David
sabinelb
Message 8 of 8
Re: My BT infinity
Thank you for your help.
I have reported this to BT this afternoon also.
Fault on the line has been confirmed. I hope it is X times lucky
