stacymc25
Message 1 of 8
My Neighbours are able to order BT Infinity but we cant
Everyone on my street is able to connect to BT inifnity but us, I have check the DSL checker online and its is showing nothing for FTTC for us but my neighbours it is all showing as available so I know its not a capicity or EO issue as we are connected through the same CAB. I think it must be soem sort of Data Base issue does anyone know how I can get that resolved
Thanks in Advance
7 REPLIES 7
imjolly
Message 2 of 8
Re: My Neighbours are able to order BT Infinity but we cant
if on same cab then write to openreach  https://www.formwize.com/run/survey3.cfm?idx=505d040e0b080d
if you get an automated reply then write again until you get a response from an actual person
stacymc25
Message 3 of 8
Thanks I have done this twice now and been told that it is being sent to a specialist but there is still no resolve
imjolly
Message 4 of 8
just need to persevere as only openreach can help you with your cabinet problem
JohnC2
Moderator
Moderator
Message 5 of 8
Hi @stacymc25 Sorry you have not been able to order Infinity.
Has your telephone line been connected long?
I ask this as it can sometimes take a few days after it has been activated and Openreach update the records before Infinity will show available on the line.
Cheers
John
stacymc25
Message 6 of 8
The line has been active for 4 weeks the error is with my address
stacymc25
Message 7 of 8
thanks
JohnC2
Moderator
Moderator
Message 8 of 8
Hi @stacymc25 Thanks for posting back and it has been connected long enough for the records to be corrected.
What @imjolly has said is correct and Openreach are the only ones who can correct the records but this is taking much longer that I would expect for an active telephone line. Drop us over your details and we will be happy to check everything is correct at our end for you. You can contact us by clicking on my user name and selecting contact the mods.
If you receive any further updates from Openreach then please do update the thread.
John
