Message 1 of 4
My TV Box won't wake up. Just one blue light comes on and the waking up process goes on and on.
3 REPLIES 3
Message 2 of 4
Re: My TV Box won't wake up. Just one blue light comes on and the waking up process goes on and on.
Hi, we are having exactly the same problem. did you find a solution?
Message 3 of 4
I had this problem yesterday. Powered off and on using the switch at the back and it turned on normally. But could be a sign the box is on its way out (had a couple of lock ups recently).
Message 4 of 4
Hi we have resolved it! by going to My BT and  following the steps for  fixing a problem with youview box. The problem was we needed  to update our soft ware. You get instructions how to update software and follow them with a lot of patience. Good luck!
