Message 1 of 5
My connection just gets faster
Back in February:
Today:
System Up Time 147:58:00
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA3793383924650310263145:02:24
LAN10M/100M2652177257300806061452147:57:42
WLAN11M/54M/270M227646189090042158147:57:45
ADSL LinkDownstreamUpstream
Connection Speed18008 kbps1219 kbps
Line Attenuation22.3 db11.4 db
Noise Margin8.8 db5.7 db
Anyway, thanks for the good service.
4 REPLIES 4
Recognised Expert
Message 2 of 5
Re: My connection just gets faster
Good to see everythings going hunky dory for you 🙂 .  The members of the forum and the Mods really appreciate the posotive feedback. 🙂  Its nice to see something going right, instead of wrong.
Message 3 of 5
Hi i agree with Edd good to hear the good news your speed could improve even more as your noise nargin is still high at 8.8 normal default is 6 may be worth contacting the mods and asking them to reset your noise margin
Message 4 of 5
Thanks for the reply.
Yes, my noise margin seems to have a target of 9db, been like that for a long time now. Initially my connection had teething troubles and the margin began much higher (maybe 15db) so I'm fairly happy.
Regards,
Peter
Message 5 of 5
That's OK i agree it is a good speed my comments were just meant to say it could still be better but if you have had a higher margin for line stability and you are happy then stick with it
