naasei
Newbie
Message 1 of 3
My infinity speed is worse than a dial up modem
I am getting a download speed of 18.6Kb (yes kilobytes) on a newly upgrade infinity line
Acording to my order cofnrimation I am meant to get download speed of 64MB/S. I am not even getting 1/100 of that. I  Have nothing runnning apart from software I am downloading. There are no other users on this network. Only laptop is connection by ethernet cable to the hub. Wifi on the laptop is disabled.
Uisng http://www.speedtester.bt.com/ to test I get an error message below "
If there is no fibre coming into my proerty that means I have not been upgraded to infinity!. Weird
FAQ
Blank Image not loaded
No Fibre to the Premises (FTTP) services have been found at this address. Please check the postcode or use the Telephone Number or Service ID to conduct the test.
Click here to try again.
2 REPLIES 2
Guru
Guru
Message 2 of 3
Re: My infinity speed is worse than a dial up modem
Hi,
You will probably be on FTTC which is Fibre to the Cabinet and not FTTP (which is Fibre to the Premises)
Please try http://speedtester.bt.com again
and click on the button that looks like:
Then post the results with the IP Profile.
Also please do the speed test with a wired Ethernet connection from the homehub/router to your computer as wireless (wifi) connections can pick up interference.
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Ratty2012
Recognised Expert
Message 3 of 3
FAQ
I very much doubt that you are getting 64MB/S anyway as you don't get even half that on FTTP I think you mean 64Mbps
