Message 11 of 23
Re: My poor BB
if your noise margin is jumping around then sorry but can you try the quiet line test again and see if you can hear noise.  there is no point in your making connection changes if there is a problem with the quiet line
There was a poster recently with the filtered faceplate which had a fault and connection improved in test socket - but that really is uncommon on the forum
Message 12 of 23
Re: My poor BB
Okies just done another Quiet line test.
On picking up the reciever theres alot of noise you can hear over the dialtone,
with the quiet line test running after a few seconds it seems to go quiet but if you hold on the noise reccurs randomly, a scratchy crackling
Worth trying the quet line in the test socket ?
Gary
Message 13 of 23
Re: My poor BB
Of course its worth it, why did i even post that,
Just taken the plate off and popped a filter in and just the phone, still random scratchy crackles
will leave it like this and see what occurs no point disconnecting it again
Thing is the lady from support tested the line and said it tested fine.
Message 14 of 23
Re: My poor BB
In the test socket with microfilter i'm now getting this
Summary Status
DSL Link:Connected
Internet:Connected
Internet Details
Broadband Link Type:Built in modem - ADSL
Connection Type:PPPoA
User Name:bthomehub@btbroadband.com
Current Internet Connection:
IP Address:86.139.221.35
Subnet Mask:255.255.255.255
Default Gateway:217.47.157.140
Primary DNS:217.32.171.22
Secondary DNS:213.120.234.2
Host Name:
Domain:
MAC Address:--:--:--:--:--:--
MTU:1500
DSL Details Down Up
Modem Type:Built in modem - ADSL
DSL Line (Wire Pair):Line 1 (inner pair)
Current DSL Connection:
Rate:928 kbs448 kbs
Max Rate:928 kbs780 kbs
Noise Margin:9.0 dB16.0 dB
Attenuation:63.0 dB31.5 dB
Output Power:16.8 dBm12.4 dBm
Protocol:G.DMT Annex A
Channel:Interleaved
DSLAM Vendor InformationCountry: {46336} Vendor: {TSTC} Specific: {4 }
ATM PVC:0/38
Rate Cap:928 kbs
Attenuation @ 300kHz:63.0 dB
Uncanceled Echo:-17.1 dBOk
VCXO Frequency Offset:7.2 ppmOk
Final Receive Gain:34.5 dBOk
Impulse Noise Comp. Tones:0Ok
Excessive Impulse Noise:0Ok
Traffic Statistics
Bytes Packets Errors % Cells Errors %
IP Traffic
Transmit:24463822062600
Receive:182064921680300
ATM Traffic
Transmit:61533600
Receive:382653200
DSL Link Errors
Collected for 10Days12:37:39
Reset 24-hr int. 15-min int. Last Event
 SinceCurrentCurrentTime Since
ATM
Last Event
Cell Header Errors20596142850:00:15
Loss of cell Delineation866369440:03:57
DSL
Link Retrains:23300:40:13
DSL Training Errors:6741000:39:39
Training Timeouts:0000:00:00
Loss of Framing Failures:40600:40:13
Loss of Signal Failures:100020:09:02
Loss of Power Failures:0000:00:00
Loss of Margin Failures:100020:09:02
**bleep**. Seconds w/Errors:656730650:00:15
**bleep**. Sec. w/Severe Errors:2953100:40:13
Corrected Blocks:1198244171130:00:15
Uncorrectable Blocks:25436190450:00:15
DSL Unavailable Seconds:542822649800:39:25
Oddly Quiet line test still has quite alot of crackle on the line.
Edit, not odd i guess as now the noise margins back upto 15 in the time i took to post the message
Message 15 of 23
Re: My poor BB
well the change has improved your connection speed to 928 - not great but at least in right direction
if you try the quiet line test at random and still get noise/crackle then need to try 151 and complain about noise when making phone calls - no mention of broadband  - problem is with phone calls
Message 16 of 23
Re: My poor BB
Aye,
I'll keep checking the noise and the routers page and try and keep records, the weathers good right now, not really windy and its dry.
If the speed doesnt get above 1Mb then i've 'only' lost about .6Mb of speed from what we've been getting for the last few years, but i dont hold out much hope of keeping this connection rate to be honest given the performance over the last 3 to 4 months.
What i did just see after trying to get onto Black ops is an apalling ping in the region of 900 to 1500ms compared to my usual 50 to 90 range. Ran the pingtest.net and get this... No online gaming for me
http://www.pingtest.net/result/52485463.png
Message 17 of 23
Re: My poor BB
you can check here to see if any exchange listed problems  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
if you can get rid of the noise you should manage to get 1.5mb and maybe more
Message 18 of 23
Re: My poor BB
Been a crummy few days but theres finally an engineer booked to look at it tomorrow,
Summary Status
DSL Link:Connected
Internet:Connected
Internet Details
IP Address:86.139.222.139
Primary DNS:194.72.0.98
Host Name:
Domain:
MTU:1500
DSL Details Down Up
Rate:320 kbs448 kbs
Max Rate:1396 kbs744 kbs
Noise Margin:27.0 dB15.0 dB
Output Power:15.3 dBm12.3 dBm
Channel:Interleaved
ATM PVC:0/38
Rate Cap:1396 kbs
Uncanceled Echo:-15.9 dBOk
VCXO Frequency Offset:4.3 ppmOk
Traffic Statistics
IP Traffic
Transmit:5199027044141900
Receive:21152381936844800
ATM Traffic
Transmit:339157900
Receive:1328448900
DSL Link Errors
Collected for 2Days23:18:47
ATM
Last Event
Cell Header Errors20561905302:40:38
Loss of cell Delineation11981592702:40:38
DSL
Link Retrains:20303:03:28
DSL Training Errors:84229705:54:32
Loss of Framing Failures:521502:52:29
Loss of Signal Failures:22306:54:38
Loss of Margin Failures:22306:54:38
**bleep**. Seconds w/Errors:3149141502:40:38
**bleep**. Sec. w/Severe Errors:46521502:42:58
Corrected Blocks:716033093800:04:40
Uncorrectable Blocks:245711073002:40:38
DSL Unavailable Seconds:29084371203:03:09
thse error stats must mean something to someone to me it just looks bad
Tags (1)
Message 19 of 23
Re: My poor BB
your connection speed is even worse than before and your noise margin is very high at 27 as normal about 6.  just need to wait now on engineer visit
Message 20 of 23
Re: My poor BB
Well,
Engineer guy came out today did a few tests capacitance is high but prolly due to long line, theres a resistance difference
between the pair something around 50 ohms, he says that should be more like 2 ohms roughly.
Popped a sig generator on at y end and off he went to do his stuff down the line, came round a couple of hours later to tell me he's given up for the day on my fault !  Honestly i dont blame him and i  seriously dont feel an ill will, the back roads hes working are sheet ice and the lines run along some basic gravel roads so after falling over a few times and then getting his van stuck he's called it off till it thaws a bit. Fair doo.
He did say he'd got to a point not too far away where the signal was pretty good and given theres not much more line to
go from there he's sure theres a resolvable fault in the last run of wire, soo depending on the weather staying a bit warmer and whenever they can shedule him in again to test/fix the remaining overhead we might have a resolution.
Not sure what else he did whilee he was out there but when it was reconneced it synched at 1280Kbs which is faster than its done in ages and its been up 9 hours which is already a plus.
so thanks to the nice chappy today,
Gary
