mcronline
Message 1 of 9
MyBT app
I upgraded my phone to one running android 5.1 from one running 5.0.
I went to install all my apps I had on my old device were installed but the mybt and the BT WiFi app are showing as not compatible. Is it because BT haven't updated the app for the newer android or is it my phone.
Its a cubot android phone and apart from that it is a giid phone. I wouldn't worry about it but every time I open mybt in chrome it offers the app which is a minor annoyance.
8 REPLIES 8
NeilO
Moderator
Moderator
Message 2 of 9
Re: MyBT app
@mcronline the MyBT app should be compatible with 4.3 and above and BT Wifi on 4.0 and above.
mcronline
Message 3 of 9
Re: MyBT app
In the app store it definately says not compatible. Only the usage app works (thank goodness).
mcronline
Message 4 of 9
Re: MyBT app
Also on download li k so I cannot force install it to see
NeilO
Moderator
Moderator
Message 5 of 9
Re: MyBT app
@mcronline I'll ask the app team for some clarification on this and post back when they reply.
Cheers
Neil
mcronline
Message 6 of 9
Re: MyBT app
Thank you. BT WiFi app is also incompatible. I look forward to the answer.
grahammm
Message 7 of 9
Re: MyBT app
I have a similar issue on my cubit x17 phone. The BT WiFi app showed as incompatible after I did an OTA Android update.
NeilO
Moderator
Moderator
Message 8 of 9
Re: MyBT app
@mcronline I also included the BT Wifi issue in my report to them.
mcronline
Message 9 of 9
Re: MyBT app
Thank you!
