Message 1 of 4
NAS Device not showing up on Home Network
I recently got a HomeHub 5 after I moved.
I have a Synology DiskStation 212j NAS which I connect using an ethernet connection.
To allow accessing it from the Internet, I have configured port forwarding on the Hub.
Everything worked fine until the next router reboot (which hqppen quite frequently as this router seems quite unstable, but this is another topic).
After a reboot, the device, although physically still connected and visible on the network, does not shoz up on the Home Network diagram, and port forwarding to it no longer works.
Only workaround I have found so far is to connect it to another ethernet port ...
Any one could help please?
3 REPLIES 3
Message 2 of 4
Re: NAS Device not showing up on Home Network
There is a guide on this page, written by a forum member. This does work provided you follow all the instructions.
SYNOLOGY DS214 - Remote access via BT Home Hub
It should also apply to your model.
Message 3 of 4
This is working, fantastic!
The only thing I had done wrong was to select my device by name instead of 'by user ip adress'.
Thank you so much for your help!
Message 4 of 4
I am pleased it is sorted Smiley Happy
That information page was provided by forum member kayster who I was assisting with their problem.
It seemed a good idea to make it available to other BT Internet users.
