geaves
Expert
Message 171 of 367
Re: I have NAT Type 2 on my ps3 yet i still have a strict NAT?
@alexmaza53 wrote:
Today i downloaded the update for Call of duty Black Ops and after it told me i had a strict Nat type however when i ran the internet connection test it told me i had Nat type 2 which i presumed to be the good one? then i went on fifa and it told me i have a moderate Nat type and then i went on call of duty modernwarfare 2 and i had an open Nat type. could someone please tell me how to get an open Nat type on Call of Duty Black ops? Thanks
The issue is with Activision, you'll need to do some port forwarding on the Hub.
ranjith08
Newbie
Message 172 of 367
which one you have portfoward coz im having the same problem but mine is on moderate
geaves
Expert
Message 173 of 367
You should not have a problem if the NAT is 2, but if you're having problems have a look here http://community.bt.com/t5/BB-in-Home/PS3-ISSUES/m-p/77529#M45083
wally10
Message 174 of 367
Re: PS3 ISSUES
Ive added all the ports yeah, and like i say when i try adding the ps3 to dmz the ps3 wont sign in i just get that dns error alltime
r1sh12
Expert
Message 175 of 367
Re: PS3 ISSUES
Give your PS3 a static IP address and the NAT type will be open.
Go to the home hub advanced settings, home network.
FInd the ps3 select it.
Then some where near the bottom click a box which says always use this IP adress.
Restart the home hub and the PS3.
Let me know how that goes.
meaga-byte
Message 176 of 367
Re: PS3 ISSUES
OOO i like that. easy to follow instructions.
Few of my friends have been having this issue tonight during COD BO but not me.
I think it may be down to a homehub thing? Im using a netgear and NAT seems to be open.
Static ip is set on the PS3 tho and not router.
Google search shows many BT homehub users with this problem.
Again might be BT HH related?
_______________________________________________________
If I've helped, just click the Star - Every little bit helps 🙂
If you can't fix it with a hammer, you've got an electrical problem.
wally10
Message 177 of 367
Re: PS3 ISSUES
Yeah tried this already and no luck i think ive tried every solution there is, just seems to be a home hub 2.0 problem
pippy
Newbie
Message 178 of 367
Re: Nat Type Strict
I had same probs with Black Ops. This was the only way i could get it to work for me after wasting time trying to open ports etc. Very many thanks for the tip.
Tags (1)
wally10
Message 179 of 367
Re: PS3 ISSUES
Would it be worth me ringing bt and asking for the type B home hub 2.0 as at moment i have type A and by all accounts there the dodgy ones
also whats the diffrence with type A and Type B hubs the seem identical
meaga-byte
Message 180 of 367
Re: Nat Type Strict
There are a few other posts on this.
It seems to be a HomeHub problem. Not a game problem.
Few mates had the same problem tonight who are using BT HH.
Im using a netgear instead and have had no problems with NAT and COD BO 😄
After some googling it seems only to effect users with the Homehub. Not sure what version tho.
If its A then maybe ask for a HH Version B?
