Hi This has probably been asked already but here goes. I have base tv package entertainment can I add NOWTV skysports without losing eurosport, gold & syfy etc? I've looked through packages & it seems my only option is to stay as I am then purchase skysports from NOWTV & use the youview app albeit no recording. Thanks
Nope.. to add any form of NowTV to BT TV you have to change to one of the news. Best option for now is to buy passes direct from NowTV or someone flogging discounted passes and use the app
Thanks hopefully things will change given time.
Just been talking to an advisor who suggested taking out the entertainment pack. Then adding bt sports, nowtv skysports and amazon prime(which includes eurosport! I don't think it does). Also what is the full list of channels on the entertainment pack or the other packs come to that? On a side note I cancelled my HD extra today, I was told I would still be able to view it till the next bill it's gone off already no problem just hope I still don't get billed for it.
Amazon has Eurosport as an add on subscription £6.99, so you could go down that route if you wish. Expensive though.
You can recontract and keep what you are on now.
A year of Eurosport Player is £39.99, up front. Works out at £3.33 a month.
Stay as I am for now until contract renewell. Cheers
But with no recording option. Losing Eurosport is a deal breaker for me so I'm staying put on my existing plan plus purchasing Now TV passes from Currys, etc.
Amazon has Eurosport player included.
