Message 1 of 4
NTE5c Faceplate for Digital Voice.
Can’t find the original post where I said I’d get this picture for so if you remember me saying I’d get it for you here it is.
It’s the NTE5c Faceplate for the Digital Voice Re Injection Service, which I believe BT and or Openreach have possibly now stopped?
The one pictured is for SOGEA. If I remember rightly the one that’s for Digital Voice over FTTP doesn’t have the RJ11 Port as obviously it doesn’t need it.
3 REPLIES 3
Message 2 of 4
Re: NTE5c Faceplate for Digital Voice.
I assume a double ended pstn cable is also supplied?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 4
It is/was provided. With FTTP the faceplate and cable was sent with the Hub.
Can’t speak for SOGEA.
Message 4 of 4
Hiya,
Where did you find the SOGEA front plate?
I am trying to find one but Google has been of little help.
