Anonymous
Not applicable
Message 1 of 10
National Geographic HD channel technical problems?
I've noticed the National Geographic channel since last night has been heavily pixelated with distorted colours (green) covering half the picture. Initially I thought this was a bad recording, but I notice the problem is continuing on the live broadcast this morning on the HD channel.
Can someone look into this?
9 REPLIES 9
ESKIBOY
Message 2 of 10
Re: National Geographic HD channel technical problems?
Just came to post the same thing. Just been on the phone with BT and they couldn't find a problem, but they said it might be a problem with Nat Geo themselves as my recording were picking up the same interference. All other HD channels are fine and the problem isn't happening on the standard Nat Geo channel
Is this the same problem you're seeing?
https://imgur.com/BjXhYZY
zulu17
Distinguished Guru
Distinguished Guru
Message 3 of 10
Just checked channel 373  Nat Geo HD and am experiencing same.
SD channel 317 seems fine.
PaddyB
Moderator
Moderator
Message 4 of 10
Hi Guys,
Thank you for highlighting and I'm sorry you're experiencing issues with National Geographic HD. I've asked my colleague in the BT TV to investigate. I'll post back as soon as I know more.
PaddyB
PaddyB
Moderator
Moderator
Message 5 of 10
Hi Guys,
Can you try the National Geographic HD channel again? It should be back working as normal. If you're are still experiencing issues, please let me know.
PaddyB
ESKIBOY
Message 6 of 10
Perfect, thank you!
MadRob
Message 7 of 10
Speedy resolution guys. Well done.
zulu17
Distinguished Guru
Distinguished Guru
Message 8 of 10
Thanks for pursuing @PaddyB
siteguru
Expert
Message 9 of 10
And the problem was ...... ?
Letting people know may help in future so customer support can be given pointers to help speed up the resolution.
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
Martin--W
Retired BT Expert
Message 10 of 10
Hello @Anonymous and @ESKIBOY
Many thanks for pointing this issue out to us.
In order to follow this up with you, would you be able to Private Message me with some contact details for yourselves.
Kind regards,
Martin.
