Message 1 of 6
Need a replacement for BT Home Hub 5 Infinity
Im looking to replace my Home Hub 5
I would like a router with build in VDSL but im unsure of what to get
Could someone be so kind and recommend a few, im also on a budget
5 REPLIES 5
Message 2 of 6
Re: Need a replacement for BT Home Hub 5 Infinity
If you do a search for VDSL modem/router you will find a few. Keep to known brands such as Netgear, Billion, Asus and TP-Link and you won't go wrong. Billion seem to be doing the cheapest at the moment with one costing about £65 although it does not have dual band wireless.
Message 3 of 6
Billion 8800n, cheapest but doesn't have 5Ghz wifi, TP Link TD-W9980 slightly more expensive £70/75
Message 4 of 6
If i do get just a router and use the white BT modem that i have here from my old BT home hub 3 or 4 setup, what settings do i need to put into new router?
is it something like this :
WAN -> Internet Access
WAN 2, PPPoE tab (Enable set to On)
username = bthomehub@btbroadband.com
password = <nothing leave this blank>
Message 5 of 6
The settings you have are correct but you may need to enter a password if the router requests one. If it does just use BT or anything else you want.
Message 6 of 6
Thanks guys, ive decided to go with the Asus RT-N65U Black Diamond and use the white BT modem
