Message 1 of 10
Need some help (bt infinity, speed from 36 to 14)
Hey,
I need some advice on what I should do, since I am in a contract with BT Infinity, I cant roll back.
With BT TOAL BROADBAND OPT 3, was use to get 17-21 mb download speed. Now 14 -26 has been the speed
for past few days. Infinity installed for less than 10 days.
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
Download Speed
14329 Kbps
0 Kbps38718 Kbps
Max Achievable Speed
> Download speedachieved during the test was - 14329 Kbps
 For your connection, the acceptable range of speedsis 12000-38718 Kbps .
 Additional Information:
 IP Profile for your line is -38718 Kbps
2. Upstream Test:  -provides background information.
Upload Speed
7928 Kbps
0 Kbps10000 Kbps
>Upload speed achieved during the test was - 7928 Kbps
 Upstream Rate IP profile on your line is - 10000 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
9 REPLIES 9
Message 2 of 10
Re: Need some help (bt infinity, speed from 36 to 14)
This report refers to a connection test carried out by IP address 86.145.18.45 on 21 Oct 2010 20:53:42 GMT+01:00.
Download speed 12535 Kbps
Upload speed 6171 Kbps
D/load COS 99 %
U/load COS - %
RTT 25 ms
RTT Consistency 86 %
Max Delay 26 ms
Avg Delay 5 ms
Max Bandwidth 12800 Kbps
Route Speed 20971 Kbps
Forced Idle 0 %
Route Conc 1.0
Download test h
Upload test h
TestBandwidth Speed
Message 3 of 10
could someone suggest at least something! ???
Message 4 of 10
1 day no reply!
Recognised Expert
Message 5 of 10
I beleive  the usual helpful router stats are not available from Infinity router
and that less than 10 days means speed could go up or down
if it persists ten I think only the forum mods could help
Contact Mods at
forum.moderation.team@bt.com
include a link to this topic account number and phone number
PS I WOULD DIE FOR YOUR SPEEDS
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Message 6 of 10
Few Minutes ago I decided to do some tests:
Results:
21 MEG
Then this happens:
31 MEG
Finally, this happens too,
42 MEG
Average upload speed is 8mb (UPLOAD SPEED STAYS THE SAME, I ASKED ONE OF MY FRIENDS (WHO WORKS FOR BT, he said it is because upload doesn't use fibre technology!
It uses the same old ethernet cable connection, but I am alright with the upload speed as they said the limit is 10 mb, but the limit for download is 40 mb not 45 or 47 (i was getting 47 the other day)
Message 7 of 10
Your BT friend is incorrect, both voice and data share the same copper pair back to the new DSLAM cabinet, at which point your voice follows the original copper path back to the exchange and your data, both upload and download, follow the new fibre path. It is an asynchronous service. 8 meg up is pretty good- I'm getting about 6.5 Mbps.
Message 8 of 10
Check several servers....
I just ran a check using a London server (I live in London) and got a speed of 3.5MBps.
Tried servers in Coventry and manchester and got over 35MBps!!!
Message 9 of 10
because you cant access your modem stats the only way to check your max throughput is to do a speedtest. But this is also subject to bandwidth/congestion.
I suggest doing a test at midnight, when everyone else is asleep.
Message 10 of 10
Use the BT speed test to see what your IP profile is set to if it is still 30+ you are good and just need to find a uncongested server to test your throughput properly. I have found that with some speedtesters repeat testing just get you faster and faster throughput reports clearly something not right there. If you IP profile has been reduced to 14 Mbps, and I do not think this is the case for you, then you do have a problem and BT need to check you line for errors.
