Message 1 of 10
Needing to buy BT connectors
Apologies not sure best place to posts this.
As my hub isn't in a position to be directly connected to my BT TV box I need mini connectors but is there any benefit to using BT branded ones or would a pair of powerlines I have do as good a job ?
I have Full Fibre 100 so would like to buy the best ones (determined by the cost) to get the most out of the broadband.
9 REPLIES 9
Message 2 of 10
Re: Needing to buy BT connectors
You don't have to use BT branded ones, any make will do as long as they're fast enough. I'd go for the TP-Link AV1300 or AV1000 (in that order of preference). Slower ones would probably work but you run the risk of IPC-6023 error messages
A better solution is to connect your box to the Ethernet port of a wi-fi disc if you have one
Message 3 of 10
Thanks, I have a pair that look like the AV1000, I'll need to check the model.
Message 4 of 10
Hi these are the ones I have, would they be suitable I can try them out before I go and spend money I don't need to.
just google search ZyXEL PLA5215 600
Message 5 of 10
The 600 at the end of the model number indicates that the maximum speed of these devices is rated at 600 Mb/s, it may not be the actual attainable speed.
By all means give them a go, just remember that you may well lose speed if they are not used strictly in accordance with the manufacturers recommendations, if there is a wiring fault in the house or the house wiring is in poor condition.
You could always connect a laptop to one to find out what link speed you can achieve (in Windows 10 that's Network Status/ Properties)
Message 6 of 10
Thanks for the help.
It's a new build property so wiring is up to date, I'll give them a go and see what they are like. I might end up updating them as I might have to use them for the Xbox of the wireless speed is no good (the hub is under the stairs.
Thinking about it I could maybe move the hub so it's closer to the box with the BT TV box and Xbox are directly plugged into it.
Message 7 of 10
If that means that you can then connect the TV box by ethernet cable , then yes, that would be the best solution
Message 8 of 10
Hi
I checked earlier and I cant move the hub as its connected to the phone line.
I think my only option is to buy 2 x powerline but with 2 ethernet ports.
Are powerline adapters the only option, would a network switch be any good ?
Message 9 of 10
A network switch will do fine
Message 10 of 10
Thanks, I've just seen a similar response where a switch was given as a solution to connect 2 devices to the internet.
Anything I should pay particular attention to eg brand ?
