srogers
Message 1 of 18
Neighbour (BT Engineer) has Infinity despite checker saying they can't - can I?
DISCLAIMER:
I have read the stickys!
My neighbour is a BT engineer and when I asked him about when Infinity would be available in our area, he was surprised as he already has it.
I use the checker weekly to determine if I can get the service and no luck so far. I know the exchange (Fair Oak) has been enabled for a while. I put my neighbours address into the checker and it said it wasn't available - despite him having it!
Is it possible that whatever mechanism the checker uses is wrong? Might I be eligible regardless of what the checker says?
Is there anyone on here that can help me answer these questions?
Thanks,
Sam R
17 REPLIES 17
DeanM
Moderator-Retired
Message 2 of 18
Re: Neighbour (BT Engineer) has Infinity despite checker saying they can't - can I?
When you say neighbour, do you mean next door neighbour or a neighbour half a mile down the road? What does it say when you put your telephone number into this checker: https://www.btwholesale.com/includes/adsl/main.html
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
srogers
Message 3 of 18
Available ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Featured Products
WBC ADSL 2+Up to 17--10 to 19.5Available
WBC ADSL 2+ Annex MUp to 17Up to 1.510 to 19.5Available
ADSL MaxUp to 7.5--6.5 to 8Available
WBC Fixed Rate2----Available
Thats what I get when I use that checker.
My neighbour lives opposite me.
legitimise_sailing
Distinguished Expert
Message 4 of 18
Do you have a BT phone ?
To say thanks for a helpful answer, please click the white star
ryant704
Guru
Message 5 of 18
If he lives opposite to you it's very likely you could be served by a different cabinet, ask him what cabinet he is served by.
When you did the checker with the telephone number it will tell you which cabinet you're served by.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
srogers
Message 6 of 18
Yup - I have a BT phone.
Admittedly this is based on a conversation, but the BT engineer claimed our cabinet was the same.  I live in a dead end close so we're not talking "opposite me" in any exagerrated sense of the term.
legitimise_sailing
Message 7 of 18
What does your address in the address checker say?
http://www.dslchecker.bt.com/adsl/ADSLChecker.Address?URL=&SP_NAME=a%20service%20provider&VERSION=35...
curiousfellow
Message 8 of 18
eSiennaSkye
Message 9 of 18
Use the ADSL checker that legitimise_sailing posted,
Also ask your neighbour if he can kindly use the same checker.
The checker will tell you exactly what Cabinet you are served by. If you're served by the same Cabinet then hopefully the mods can escalate this for you and get it fixed.
If you felt my post was informative and helpful then please click the star below my name/avatar.
Cheers!
srogers
Message 10 of 18
This is the full output (I already posted this, I believe) form the checker you suggest:
BT BROADBAND AVAILABILITY CHECKER
Featured Products
For all ADSL and WBC Fibre to the Cabinet (FTTC) services, the stable line rate will be determined during the first 10 days of service usage. Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 31-Mar-2014. The Stop Sale date for IPstream is from 31-Oct-2013; the Formal Retirement date for IPstream is from 31-Mar-2014.
Note: Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number check.
Thank you for your interest.
I can't see a cabinet number.
Here is the output from my neighbour oppiosite:
Featured Products
Looks the same to me - no mention of Infinity - but he has it....
