Harrisimo02
Message 1 of 6
Neighbours all have fibre in or available
My neighbours all have fibre in or else available to them.
I had the engineer out yesterday who installed a line for me and also informed me that I should be able to get fibre. He checked the cabinet I'm connected to and seen that out of a new set of 100 fibre connections there is about 80 available.
Yet when I check with the openreach or with BT their checker is telling me that I can't get fibre! Quite frustrating!! I find it really strange that my neighbours have fibre either installed or available, the engineer says my cabinet is nowhere near full but yet I can't order fibre!
Has anyone else had this issue? Any help on resolution would be appreciated.
Tags (1)
5 REPLIES 5
Webby
Message 2 of 6
Re: Neighbours all have fibre in or available
If your line only went active today, it'll take about a week formthe relevant databases to update to show it as available.
Keep checking the checker.
Harrisimo02
Message 3 of 6
Ok cheers Webby, will do!
Harrisimo02
Message 4 of 6
Hi, so the latest update I have is that when my line is checked by using my land line number I can get fibre, although when an address search is performed (NAD??) it says I can't have fibre...?
Any ideas on how to resolve would be appreciated.
pippincp
Sage
Message 5 of 6
The result from the number check is the one that matters. If it says you can get it then order.
Harrisimo02
Message 6 of 6
Cool, cheers
