aerodda
Message 1 of 3
NetProtect Plus Failure (McAfee)
My McAfee is turning itself off.  That is, I'm getting messages that "Scanning is turned off".
Every time I re-start it it locks up the PC and then... turns itself off again.
Any ideas would be graetly appreciated!
Regards
Tony
2 REPLIES 2
Message 2 of 3
Re: NetProtect Plus Failure (McAfee)
Welcome to the forum.
TBH the most consistent reply on here to such an issue is.........get rid of McAfee and try say MSE instead.
The former eats system resources and often does such strange things as many of us have found.
Having tried [say] MSE, if you dont like it you can always re-install McAfee again. If you do go for a change, run the McAfee uninstall tool just to tidy up your device.
AQ.
"Welcome to Royston Vasey - You'll never leave."
aerodda
Message 3 of 3
Thanks Allan.
Rgds
Tony
