PeterR
Message 1 of 8
NetProtect Plus
Is anybody else suffering with a persistent McAfee splash screen that tells you that the latest updates have been installed?
I cannot get rid of the splash screen which obscures a sizeable part of my desktop. I have ticked the "Do not show this alert again" box and even if I click OK the scree persists!
I am running Windows Vista 64bit.
7 REPLIES 7
Moderator-Retired
Message 2 of 8
Re: NetProtect Plus
PeterR,
Is this still happening? If so, fill out the contact us form in the about me section of my profile.
Cheers,
Chris
BT Forum Moderator.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
PeterR
Message 3 of 8
Re: NetProtect Plus
I have found the settings tab and unticked everything. This has stopped the system telling me that it has updated however the changes I make to the settings are not persistent across reboots. Unless I go to settings and untick everything each time I boot then I get a splash creen that will not go away every time I put a USB stick into my PC.
So part of the problem is solved but there is still a problem retaining settings across boot cycles.
tickhill
Expert
Message 4 of 8
Re: NetProtect Plus
Note there is another thread running about BTNet Protect Plus which, for me anyway, has just downloaded (15.12.11) a complete new update.
See:  http://community.bt.com/t5/Other-BB-Queries/BTNetProtectPlus/td-p/344779
Solutions4u
Message 5 of 8
Re: NetProtect Plus
Hi PeterR,
You need to stop the McAfee splash service by going to the services page on your computer.
PeterR
Message 6 of 8
Re: NetProtect Plus
Sorry for being thick but where is the "services page on my computer"!?
Solutions4u
Message 7 of 8
Re: NetProtect Plus
Hi PeterR
if you are using win xp, go to start(left hand bottom corner of the computer screen)> run>type''services.msc'' without quotes in the box and press ok. You will get the services page, now select the splash service from the list of services mentioned, right click on the appropriate service and stop it, also select its start up as automatic.
If you are using win vista or win 7, you need to click start>type ''services.msc'' without quotes in the start search box and press enter, follow the same process as in win xp.
Hope this will solve the problem.
PeterR
Message 8 of 8
Re: NetProtect Plus
I'm afraid not. Whatever I do I get these irritating splash screens that do not respond and persist using up valuable desktop space. I am using fully up to date Windows Vista (64bit). My old laptop using Windows Vista (32bit) didn't suffer from this, neither does my new laptop running Windows 7 (64bit). This looks to me like an issue with Netprotect's interaction with Windows Vista (64bit). Any chance that someone can get this fixed please?
