Message 1 of 3
Netflix & Android TV via BT Home hub
I have recently bought a Sony Anroid TV using it wirelessly via my BT Home Hub. I am finding that when viewing Netflix the connection will drop every 30 minutes or so and I need to go back to the main screen to resume watching. I am having no problems with any other apps, You Tube etc, on which I can view for hours uninterupted. As Netflix is the only App giving me this problem does anybody know how to overcome this?
2 REPLIES 2
Message 2 of 3
Re: Netflix & Android TV via BT Home hub
Have you turned off Smart setup? What is Smart Setup on the BT Hub? How can I turn it on and off? | BT Help
Also check the Advanced Wireless settings on your hub (Advanced settings / Wireless) and make sure it is operating in Wireless Mode 1
Message 3 of 3
hi - thanks for your prompt reply - I will do as you suggest and see if it works
