Scooby99
Message 21 of 21
Re: Netflix connection problem
Hi Keith - if I need to look at other ways to stream Netflix, while keeping BT parental controls on, I think you are saying the device needs to have a dns to match / which can be changed to match the one you suggested previously. If it can't do this it won't work ?
Cheers
