iwornmyelbows
Message 1 of 4
Netflix issue (again)
Hi - I am experiencing a repeat of the issues affecting Smart TV access of the Netflix app ( https://community.bt.com/t5/Connected-Devices-Other/Netflix-connection/m-p/1599137#M120110 ) - same circumstances (Panasonic TV - app won't load, NBP1 error message, reset doesn't solve the issue, nor does DNS adjust - app does work when tethered to mobile hotspot which would suggest is the same BT related problem). This was fixed previously with a new HH3 hub, has anyone else had trouble recently?
3 REPLIES 3
TJ1
Message 2 of 4
Re: Netflix issue (again)
I found my Home  Hub 3 would not connect to Netflix error code ui113,changed to Home Hub 5 and it solved the problem.
spakey
Message 3 of 4
same problem, Panasonic Smart TV + home hub 3. BT blame Netflix, Netflix admit there is a problem but blame BT. I've had poor performance since February 😞
spakey
Message 4 of 4
TJ1,
did BT supply the Hub 5 or did you have to buy it ?
