xmb
Message 11 of 34
Re: Netgear D6400
G.IMP has been rolled out to most Huawei cabinets but not on the ECI cabinets due to issues found during tests.
You can see what type of cabinet you have by looking at it and use the information found at the Kitz forum.
python
Message 12 of 34
Re: Netgear D6400
Ok.
I bought the Netgear D6400 this afternoon.
So far it is performing very poor some pages are slow to load.
When using speedtest .not I got a steady 37.4 download speed with a ping of 18.
Now sometimes it is slow loading speedtest.net page and when I do the test the bar is not stable at all and I am down to 34.5
If it doesn't improve I am afraid it will be returned from where I bought it, am currently in contact with Netgear support but I don't expect to get much help.
Jim
xmb
Message 13 of 34
Re: Netgear D6400
Mine is stable and working fine since I installed it over two weeks ago now. Since the forums are very quiet it is unlikely to be a router problem, unless you have been unlucky. Any mass produced item can and will have odd failures out of the thousands manufactured.
python
Message 14 of 34
Re: Netgear D6400
I have put my BT modem and wnd3700 back on for now and everything is ok.
I have been talking to Netgear support for a few days and yesterday I had an email saying :-
We will look into your case, we will hopefully release the latest Firmware as soon as possible, but then again we have no exact time as to when will it released. Rest assure that the update of the Firmware for D6400 is on process.
Waiting to see what happens when it is released.
Jim
xmb
Message 15 of 34
Re: Netgear D6400
As everyone else with these seem to having no issues and multiple users report G.IMP works fine (assuming your cabinet has this enabled) you may have a faulty router. Take a look at Kitz Forum.
Have you tried resetting your router to factory defaults then setting up again?
Steve514
Message 16 of 34
Re: Netgear D6400
Hi sorry very new to this but please can I ask,
I have bt infinity being installed in the next day or two , I have brought the netgear d6400 , I have it connect to adsl at moment , which works great but when I read the manual it's saying when you set up for vdsl it says to do it over PPPoE ?
I'm confused , do I need still to buy a open reach modem , or will the netgear d6400 connect to bt infinity which will allow all computers and devices to connect wireless ?
Please help
Thank you
licquorice
Message 17 of 34
Re: Netgear D6400
The Netgear will work fine on its own, you will need to set it up again for VDSL when you are changed over.
Steve514
Message 18 of 34
Re: Netgear D6400
That's great thank you so when it comes to re setup I change transfer mode to PTM , also need to input login details and password also cos I have an static ip but when it comes to encapsulation will I be able to use PPoA or PPPoE or is it best to let netgear genie do the set up.
Thank you
Keith_Beddoe
Message 19 of 34
Re: Netgear D6400
@Steve514 wrote:
I have an static ip
How did you manage to get a static IP on a BT Residential service, as I thought that only BT Business issues those?
Remember, this is a Residential forum, and if it BT Business specific information you need, then you would be better asking on the BT Business Forum. at http://business.forums.bt.com/
Steve514
Message 20 of 34
Re: Netgear D6400
Sorry I'm bt business ,sorry
