Keith_Beddoe
Message 21 of 34
Re: Netgear D6400
@Steve514 wrote:
Sorry I'mbt business ,sorry
Its not a problem, but I was concerned that some of the settings may be different.
licquorice
Message 22 of 34
Re: Netgear D6400
@Steve514 wrote:
That's great thank you so when it comes to re setup I change transfer mode to PTM , also need to input login details and password also cos I have an static ip but when it comes to encapsulation will I be able to use PPoA or PPPoE or is it best to let netgear genie do the set up.
Thank you
You will need to use PPPoE, but suspect the genie will sort it.
Steve514
Message 23 of 34
Re: Netgear D6400
Ok thank you , but if I understand right that means only connect devices by Ethernet cable ?
licquorice
Message 24 of 34
Re: Netgear D6400
No, PPPoE is on the DSL side not the LAN.
Steve514
Message 25 of 34
Re: Netgear D6400
Thank you that makes sense I think I got lost just a bit ,
Just was preying that I haven't wasted a load of money on a router that still needs a Ethernet cable plugged into it all the time ( would of kept my old router and brought a open reach modem )
Thank you
python
Message 26 of 34
Re: Netgear D6400
The new firmware for the D6400 was supposed to be released in June to add support for G.INP.
The latest is that Netgear engineers are still working on the new firware and they have not provided any date for it's relwase.
Lost all faith in Netgear now.
Jim
havoc421
Message 27 of 34
Re: Netgear D6400
Hi all
I just got the 6400. Instalation was seamless and got connected, however speeds are slower than my HH5. Just before I installed the Netgear I was getting around 70Mbps in speedtest and now it hovers around 20-40 with some peaks to 60 during testing.
Any tweaks I should make?
havoc421
Message 28 of 34
Re: Netgear D6400
If it helps:
ricke17
Message 29 of 34
Re: Netgear D6400
Anyone managed to get this working for IPTV?
licquorice
Message 30 of 34
Re: Netgear D6400
Have you enabled IGMP proxy? Advanced > Setup >WAN setup
