gailS
Message 1 of 4
Netgear Nighthawk R7500 settings for multicast
I have a Netgear Nighthawk R7500 and would prefer to use that than my current Home Hub 5.  The router has a setting to disable IPMG proxying - I've switched it off to allow IPMG proxying but is there anything else I need to do as I still can't get any channels other than the freeview channels?
3 REPLIES 3
licquorice
Message 2 of 4
Re: Netgear Nighthawk R7500 settings for multicast
As far as I'm aware, enabling IGMP proxying is all you need to do.
het_uk
Message 3 of 4
I don't think IGMP is the only thing you need to do. I had a R7000 and could never get that working. I tried with stock, custom and 3rd-party firmware and it never worked, apart from once when the router was still loading custom packages.
licquorice
Message 4 of 4
Can't think what else would be required unless there is some bizarre firewall setting blocking multicast packets. Might be worth asking either Netgear directly or on a Netgear forum (if there is one).
