richard_kimber
Message 1 of 3
Netgear router won't connect
I have been trying to use a Netgear AC1900 R6800 router in place of the Smart Hub 6 on my Infinity 3 (up to 200Mbps) line, but it just won't connect to the internet.  Is there something I need to know to make the connection work, or is this router not compatible with Infinty 3? I had expected connection to be automatic with the default settings.
If the latter, what third party routers are known to work with Infinity 3?
2 REPLIES 2
Liam_
Recognised Expert
Message 2 of 3
Re: Netgear router won't connect
It should work, the Internet settings you need are:
username -  bthomehub@btbroadband.com
password -  bt
PPPoE
and possibly  VLAN ID     101    this is unlikely required but just in case.
The ports all support 1 Gigabit so fine for the 200Mbps.
As it's a Netgear don't expect IPv6 to work properly.
richard_kimber
Message 3 of 3
Many thanks. I was confused about username etc.
It's working fine now.
