Hi all.
Our internet was working fine until their was a network upgrade. Since then, we have difficulty staying online. Our signal strength is excellent, we're showing as connected etc., but we can't surf the 'net. The solution is to turn our Netgear wireless modem router off and on again which gets things going. The problem arises in that we have to do the same thing the next day. Every day. Come home from work and want to go online? Power cycle the router.
It's proving a little inconvenient now, given the 10 days mentioned below have long passed. Any ideas why we have to constantly turn it off and on again?
I've tried poking about in the Netgear settings to no avail, but not to sure what needs done and am not too IT savvy.
Network upgrade email below:
This is to let you know that we've now upgraded your line and you should now have an improved, more consistent broadband connection, and maybe a speed increase.
You can find out more at bt.com/networkupgrade
Remember your line needs time to settle down
For the next ten days, your broadband might slow down or even stop now and again. That's normal and it'll soon settle down. You can help it along by leaving your BT Home Hub on and using your broadband as much as you can for this time.
Any and all input appreciated.
Cheers
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith http://forumhelp.dyndns.info/speed/first_steps.html
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Thanks for that John.
I've posted some info below.
Router Status | |
Account Name | |
Firmware Version | V2.1.00.54_1.00.54 |
ADSL Port | |
MAC Address | 20:4E:7F:F0:48:E0 |
IP Address | 86.163.160.193 |
Network Type | PPPoA |
IP Subnet Mask | 255.255.255.255 |
Gateway IP Address | 217.32.142.103 |
Domain Name Server | 213.120.234.38 213.120.234.70 |
LAN Port | |
MAC Address | 20:4E:7F:F0:48:DF |
IP Address | 192.168.0.1 |
DHCP | On |
IP Subnet Mask | 255.255.255.0 |
Modem | |
ADSL Firmware Version | A2pB023k.d20k_rc2 |
Modem Status | Connected |
DownStream Connection Speed | 12613 kbps |
UpStream Connection Speed | 1043 kbps |
VPI | 0 |
VCI | 38 |
Wireless Port | |
Name (11N SSID) | Wish You Were Here |
Name (11G SSID) | Wish You Were Here |
Region | Europe |
11N Channel | 36 |
11G Channel | AUTO |
Mode | Up to 300Mbps at 5GHz & 54Mbps at 2.4GHz |
Wireless AP | Enabled |
Broadcast Name | Enabled |
Download speed 11.05 MPS
Upload speed .086 MPS
Ping Latency 76.50 MS
Quiet test was done and it was very quiet.
However I've got two type of socket and don't know which is the master one.
the master with the test socket is shown in the link
could you alsoi locate the connection time /speed attenuation noise margins and erors please as we need that data
This is with the new type master socket.
System Up Time 00:56:08 | ||||||||||||||||||||||||||||||||
Connection Status |
Connection Time | 00:13:25 |
Connecting to Server | Connected |
Negotiation | Success |
Authentication | Success |
Getting IP Addresses | 86.171.228.5 |
Getting Network Mask | 255.255.255.255 |
Account Name | |
ADSL Port | |
IP Address | 86.171.228.5 |
LAN Port | |
DHCP | On |
Modem | |
DownStream Connection Speed | 14909 kbps |
UpStream Connection Speed | 1048 kbps |
VPI | 0 |
VCI | 38 |
Wireless Port | |
Region | Europe |
11N Channel | 36 |
Download speed 13.39 MPS
Upload speed .083 MPS
Ping Latency 409.50 MS
Do not know how to find the error stats.
It's wireless John
it is a common issue with that modem (I assume from the firmware that it is a DGND3300 ?) changing the wireless settings to 802.11g can sometimes help.
Next time the problem occurs, try connecting to the modem by ethernet cable and see if you can access the netgear app.
