LeeM
Message 21 of 33
Re: Network upgraded, download slow, upload much faster!
Sorry, one thought, could the other problem that I seem to have, wiith the internet doppping when the phone is used, be coming into play here? ie screwing up the profile?
Lee.
Message 22 of 33
it's not really the profile it's your sync speed which is very low even when connected to the test socket.  Your phone problem may be linked to it though
LeeM
Message 23 of 33
So the engineer has been and left about 20 mins ago. Thanks to Stuart for arranging.
Visit lasted about 2hrs. Testing did not show any problem with the line. I have been 'capped' at a low speed/rating which resulted in the 128K down. The engineer believes my router to be unsuitable for 21CN (it's a ver 1.5 white), and it needs upgrading NOW. Due to the router being unsuitable it has been dropping the connection, this in turn has lead to me getting a low speed profile and a cap being applied. I have been advised to wait for 2hrs for the notes to go on the system and call BT to dispatch a new suitable router.
Does this make sense and seem right to any experts out there. Right now I am still only getting 128K down. Stats from my router below.
Comments welcome..please! I think/hope I am getting there.
Lee.
Link Information
Uptime:0 days, 0:21:09
Modulation:G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:440 / 11,257
Data Transferred (Sent/Received) [MB/MB]:1.63 / 7.66
Output Power (Up/Down) [dBm]:12.0 / 0.0
Line Attenuation (Up/Down) [dB]:12.5 / 30.0
SN Margin (Up/Down) [dB]:29.0 / 6.5
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):0 / 800
CRC Errors (Up/Down):0 / 1
HEC Errors (Up/Down):0 / 1
Line Profile:Fast
LeeM
Message 24 of 33
Oh and my profile has been reset to a higher speed as seen in the router stats, speed still 128K as mentioned, guess this takes time to build up?
Lee.
Message 25 of 33
The old hub 1.5 is ADSL2+ capable, and the fact that you are synced at 11257 kb proves this.
You may find that this will reduce, as the exchange finds the most stable speed.
The IP profile will take a while to adjust itself, so the actual download speed may be slow at first.
LeeM
Message 26 of 33
Hi Keith,
Now Sunday evening. I have seen a small increase in speed, now getting about 350Kb down so better than 128Kb but way off where I was. Given that the IP profile was reset at about 10.30/11.00 Thurs morning when should I see normal speeds?
Thanks.
Lee.
Message 27 of 33
can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester http://speedtester.bt.com and post the results.
Someone may then be able to offer assistance
LeeM
Message 28 of 33
Here you go:
Link Information
Uptime:3 days, 8:53:08
Data Transferred (Sent/Received) [MB/MB]:95.06 / 410.43
SN Margin (Up/Down) [dB]:28.5 / 6.5
Loss of Signal (Local/Remote):2 / 0
Error Seconds (Local/Remote):5 / 0
FEC Errors (Up/Down):0 / 6,315,356
CRC Errors (Up/Down):0 / 965
HEC Errors (Up/Down):0 / 818
Line Profile:Fast
Message 29 of 33
stats look good apart from the upsync which I would have expected to be 800/1000.  what about btspeedtester?
LeeM
Message 30 of 33
Here are the speedtester results, it keeps asking to do a 'last test' which requires some reconfig, should I be doing that?:
Download speedachieved during the test was - 54 Kbps
 For your connection, the acceptable range of speedsis 100-250 Kbps.
 Additional Information:
 Your DSL Connection Rate :11257 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 0.0:17.55:82.45 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload speed achieved during the test was - 334 Kbps
 Upstream Rate IP profile on your line is - 440 Kbps
