DylanThomasMod
Message 1 of 23
New AntiVirus
Do you think BT are going to partner with a new antivirus provider? McAfee is rubbish and doesn't detect anything Smiley Frustrated maybe Bitdefender Smiley Very Happy like that is going to happen. But seriously new provider?!?!?!
Dylan
BT More Broadband (ADSL)
22 REPLIES 22
Keith_Beddoe
Message 2 of 23
Re: New AntiVirus
Do you have a problem with the BT product, or are you just wanting to start a general discussion?
DylanThomasMod
Message 3 of 23
Re: New AntiVirus
Yes the reviews & expert tests reviews are rubbish. I have bitdefender free edition and it is nice but not the full version and if BT would change the provider it would be nice to have a full suite of security (instead of windows firewall and windows defender)
Dylan
Keith_Beddoe
Message 4 of 23
Re: New AntiVirus
I just use Microsoft Security Essentials, but I am sure you will get feedback from other forum members on which is best, but I doubt that BT will change provider.
ryant704
Guru
Message 5 of 23
Re: New AntiVirus
Personally, any anti-virus that uses less resources is all you need. Any new viruses/key loggers aren't detected for a long while all you really need to do is protect yourself from shells and just don't visit dumb websites.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
stuartrogerson
Distinguished Guru
Message 6 of 23
Re: New AntiVirus
I got fed up with  most of them years ago. All have good and bad points.
Then I decided to move the entire family over to Macs.
Now I am happy.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
zagnome
Message 7 of 23
Re: New AntiVirus
Patching is the most important thing to do these days. Secunia PSI will help you a lot.
If you must install an AV solution, have a look at Security Essentials.
Don't forget to run regular onsite and offsite backups.
pottyperson
Distinguished Guru
Distinguished Guru
Message 8 of 23
Re: New AntiVirus
People have various problems with BT's offerings and generally you have to sympathise. But not with NetProtect. It's awful but you don't pay extra for it, it's not compulsory, and there are plenty of superior, free alternatives.
magpie03
Expert
Message 9 of 23
Re: New AntiVirus
I think Macfee is great and I'm please bt use them. best other one I would say is MSE very good officical product.
EndofDays
Message 10 of 23
Re: New AntiVirus
For me Eset is the best.It takes only less resources.
