Message 1 of 3
New BT Hub 4 will not connect to printer
I've received a new BT Hub 4 all working fine except it will not connect to my Epson WF-2510 Printer, it worked perfectly before, I've tried everything, can anyone help,
2 REPLIES 2
Message 2 of 3
Re: New BT Hub 4 will not connect to printer
You have to connect the printer to the Homehub. If you get the printers instructions and follow the first time set up guide. Make sure you use the wireless passkey on the Homehub label and not the admin password.
Message 3 of 3
You will probably have to run the Epson setup wizard, but make sure you turn off smart setup on the home hub first.  http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
