Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi,
Had BT infinity installed this morning and all semed ok when the engineer left (speed test showed 75 MB down and 5 MB up, thought upload should be 20MB but hey....)
Now everything has ground to a halt taken 30 minutes just to get to this forum - speedtest either fails to run with an error or says my upload speed is between 0.00 and 0.07
I could understand some instability as new install but surely this can't be normal? Who can I call - I assume as new install I can call the guys that fitted it somehow?
Speedtest results:
Download Speed (Mbps): 75.37
Upload Speed (Mbps): 0.00 (yay)
Ping Latency (ms): 61.38
Peter
Solved! Go to Solution.
Hi Ray,
Says no data available
Regards
Peter
The order conf email I got from BT said:
We estimate your download speed will be up to 76Mb.
We estimate your upload speed will be up to 19Mb.
I assume you have had a Homehub 5 installed. Can you post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk.
Here you go:
1. Product name: | BT Home Hub |
2. Serial number: | +068343+NQ41525216 |
3. Firmware version: | Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown |
4. Board version: | BT Hub 5A |
5. WAN: | PPP Connected |
6. Data sent/received: | 165.8 MB / 2.3 GB |
7. Broadband username: | bthomehub@btbroadband.com |
8. BT Wi-fi: | No |
9. 2.4 GHz Wireless network/SSID: | Skipper |
10. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 150 Mb/s)) 20 MHz, WPS enabled |
11. 2.4 GHz Wireless security: | WPA2 |
12. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
As Ray has already asked, do you have another device that your Homehub is connecting to such as a white Openreach modem?
Your stats on a Homehub 5 should look something like this, where as yours is showing a WAN connection rather than a VDSL connection.
2. Serial number: | xxxxxxxxxxxxxxxxxxxx |
5. VDSL uptime: | 0 days, 18:05:23 |
6. Data rate: | 11188 / 15892 |
7. Maximum data rate: | 11535 / 16464 |
8. Noise margin: | 7.0 / 7.4 |
9. Line attenuation: | 0.0 / 16.7 |
10. Signal attenuation: | 0.0 / 16.8 |
11. Data sent/received: | 58.3 MB / 147.9 MB |
12. Broadband username: | bthomehub@btbroadband.com |
Yes it connects to a white BT openrach "device" that the engineer fitted to the wall of the office
