marcuspos
Message 1 of 7
New BT Smart Hub - couple of questions
Hi, a couple of questions regarding my new HH6....
1) does inserting the router via a filter direct into the tester socket of the BT master socket improve internet quality/speed?
2) is it best to have the router only say half a metre from the master socket - less cabling = less interference, right?
Cheers
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: New BT Smart Hub - couple of questions
Cheers
It depends on if you have any extension wiring. If you do, then a filtered master socket is best. Like one of these.
LINDY VDSL2 Microfilter Faceplate
The length of the RJ11 lead does not really matter too much, as the distance is sort compared to the distance to the exchange or cabinet, depending on what broadband service you have.
Connecting things upa as shown below, is a quich way to test the maximum possible connection speed.
marcuspos
Message 3 of 7
No extension wiring, no telephones anywhere else in the house - we only use the landline for broadband.
The current broadband cable from the filter/master socket to the router is approx 2 metres long - this ok?
Keith_Beddoe
Message 4 of 7
That fine, but you do need to keep a phone for testing, and to maintain the connection.
See this post https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/No-Internet-and-horrible-bt-customer-service...
marcuspos
Message 5 of 7
So, pretty much ok to leave the router (via a filter) straight into the test socket if it has improved spped/reliability a bit? Is it a bit of a myth really that a longer broadband cable affects performance that much in the grand scheme of things?
Keith_Beddoe
Message 6 of 7
If you had a very long poor quality cable, then you may see a reduction in connection speed.
If you post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
It will give the full connection information.
You can compare that with the expected connection speed range you were given by BT.
marcuspos
Message 7 of 7
OK, cheers, will leave all as is for now
