smithkg1
Message 1 of 2
New BT Youview box
Brand new BT Youview box connected ok to Plusnet broadband - Switch all on and 'Waking up' screen opens, stays for about a minute then TV screen goes blue. HDMI1 is correct port and properly set.
No remote controls or box top controls operate except to switch off.
It's a Toshiba TV and worked before with the older BT box until a loose connection required me to replace it. Any ideas?
Tags (1)
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: New BT Youview box
I suggest that you post on the Plusnet user forum, as this is the BT Broadband forum, and the issue may be broadband related.
https://community.plus.net/t5/TV/bd-p/TV
Your YouView box will get the Plusnet  branding once the ISP configuration is updated. I assume its a retail YouView box, so it may take a while for it to download the latest update over your broadband.
