jaketame
Message 1 of 4
New Build
Hi,
I have just moved into a brand new property and all our sockets are built into the wall, unsure on the master anyway.
We have our phone line installation on the 30th November, yes I know weeks away for someone that works from home regularly!
Our postcode does not get picked up and checks yet however the road that leads to ours does and this is fibre enabled.
Is anyone able to assist as I would like to know so then I can book an engineer for fibre install asap as I need internet!
Thanks.
3 REPLIES 3
Message 2 of 4
Re: New Build
If available to you you cannot get infinity until your line goes live
jaketame
Message 3 of 4
Re: New Build
Great, thanks. 30th November it is then 😞
Message 4 of 4
Re: New Build
Although the 30th your line goes live It does not mean that Infinity is available on your cabinet at that time you will be able to get more details then
