mick2165
Message 1 of 17
New Cabinet
I have had infinity 1 since it came to my village and it was fine but now there is a new box installed closer to my house with loads of new houses connected which has reduced my speed considerably. How do i go about getting moved to this new box without endless phone calls, any help appreciated.
16 REPLIES 16
Keith_Beddoe
Message 2 of 17
Re: New Cabinet
You can`t, as the external network is fixed, and your house would be cabled to your existing cabinet. Openreach would have to dig up the road and run new cables, and all the customers served from your loacl cable would have to be moved.
That will not happen.
The new houses on the new cabnet, would not affect your connection speed.
mick2165
Message 3 of 17
Re: New Cabinet
Thanks for your reply Keith but my connection is fibre to cabinet so that would not apply to me.
Keith_Beddoe
Message 4 of 17
Re: New Cabinet
Why not? If  you are talking about a new fibre cabinet that has been installed, then that would only serve those houses that are cabled to that cabinet.
You would be cabled to a different cabinet, and cannot be moved.
Perhaps another forum member would comment as well?
licquorice
Message 5 of 17
Re: New Cabinet
Absolutely correct Keith.
mick2165
Message 6 of 17
Re: New Cabinet
I would thank you again if you made any sense i was originally connected to an old cabinet a few yards from where the second fibre cabinet is now, the first fibre cabinet to come to my village was half a mile away and they moved my connection to there so what is stopping them from shortening my connection back to where it was originally.
licquorice
Message 7 of 17
Re: New Cabinet
What exchange and cabinet numbers?
Keith_Beddoe
Message 8 of 17
Re: New Cabinet
Your connection is just one of many in the distribution cable that runs from the cabinet, to serve the customers of all service providers in your road.
Its not possible to simply take out your pair and route it elsewhere.
Webby
Message 9 of 17
Re: New Cabinet
Unless this is an infil AIO cabinet.
Many assumptions seem to have been made.
Openreach can and are currently rearranging thousands of copper lines to improve the FTTC speeds of customers through various BDUK schemes.
pippincp
Sage
Message 10 of 17
Re: New Cabinet
Why do you think it doesn't apply to you?
