robinbredin
Message 1 of 3
New HH for Infinity
What it is, I have Infinity, and have the router and HH2 connected to it. What my question is, "Can you run Infinity with just the new HH3, or will you need the router as well".
2 REPLIES 2
wedd1ng528
Message 2 of 3
Re: New HH for Infinity
From looking at the pictures on an earlier thread under BB in Home it looks as though the HH3 is essentially a router (just like the HH2). So if like me you are using a router that is not supplied by BT then the HH3 is probably not for you (unless you want to splash out £50 for the HH3. Suggest you have a search on this forum for HH3.
wedding
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
Paingiver
Message 3 of 3
You will still need the Openreach vDSL modem with the HH3.
