Keith_Beddoe
Message 11 of 17
Re: New Home - phone line works but no broadband
@talbot649 wrote:
Sorry and yes MyBt says everything is done.
Can`t see there is much else that can be done at this point. It could be that the exchange task was closed without the work being done, or there is a faulty broadband port on the equipment.
Its also possible that the last people had BT Infinity, and the wiring in the cabinet has not been removed. That would stop the ADSL broadband, as it has filters in.
A visit by an Openreach Field Technician would confirm this, as they could see whether it was still routed via the fibre cabinet.
The commissioning of ADSL broadband is done from the exchange frame, so a wiring issue in the cabinet would not show up.
I would consider the cabinet wiring error as my best guess.
talbot649
Message 12 of 17
That's great thank you, I'll ring BT and run some possibilities by them.
Keith_Beddoe
Message 13 of 17
I would ask the moderators to take a look, but it would be a few days before they could pick it up.
I think a visit is going to be the only option, so I doubt that the broadband helpdesk could do much, as it needs to go to Openreach, so make sure that they do not cancel the visit.
DavidM
Moderator
Moderator
Message 14 of 17
Hi @talbot649 and thanks for posting.
If you're still having problems after calling drop me over an email with the details and I'll check this for you. You'll get the contact the moderators link in my profile if you need it.
Cheers
David
talbot649
Message 15 of 17
So the Openreach engineer called me before coming this morning, I passed on the suggestion that a filter (or something) may have been left in the cabinet from the previous customer's fibre connection. He stopped there first, removed it, and the broadband was working by the time he knocked on the door.
Thank you for all your help, I'm pleased it's resolved but annoyed that something so simple caused the inconvenience this week!
talbot649
Message 16 of 17
Thanks for all the help on this forum, much better than BT customer services!
Keith_Beddoe
Message 17 of 17
Just as I guessed Smiley Happy
I suspect this is often forgotton, unless the cabinet is full, and the port is needed for another customer.
It does however leave me wondering how many "full" cabinets are only full because old circiuts have not been ceased ?
