john46
Message 11 of 15
Re: New Infinity 1 - Stuck to be on 40/10 product rather than 55/10 ?
no problem the difference is due to network overheads no one achieves the max rate
bigwest
Message 12 of 15
Just to update. I'm now getting the following which is more what I was expecting originally.
Downstream sync speed:
46.81 Mbps
Upstream sync speed:
7.69 Mbps
Maximum data rate:
7688 / 45976
Noise margin:
5.8 / 5.9
Maybe G.INP got turned on for my line.
John25Roberts
Message 13 of 15
Yep, there's certainly no 40/20. Just 40/2, 40/10, 55/10 and 80/20. There will soon be a new one, an 18 down but not sure what upload it will have. Probably just 2.
Webby
Message 14 of 15
Correct, 18/2 but it won't be available to every line as far as I know.
John25Roberts
Message 15 of 15
I'd imagine it will be purely aimed at those who will be on Long Reach VDSL when it eventually becomes available.
