G4HLF
Message 1 of 15
New Install, Huawei DSLAM ECI Modem
Hi all, Just appreciate your thoughts on this. New install today, getting approx 75 down 18 up. The DSLAM down the road is a Huawei unit so thought they might supply a Huawei cable modem but the engineer turned up with an ECI one and told me the Huawei was unreliable. I presume there is no effort to match the modem with the DSLAM, just in my mind you would like to think that same manufacturer would be better option for compatibility/performance? Regards, Paul
14 REPLIES 14
Deathtrap3000
Recognised Expert
Message 2 of 15
Re: New Install, Huawei DSLAM ECI Modem
Nothing wrong with mixing and matching. You could buy your own vdsl modem if you wanted. The huawei ones arent unreliable, he is misinformed.
TimCurtis
Recognised Expert
Message 3 of 15
I too am on a Huawei DSLAM & OR supplied the ECI modem.
I bought a brand new Huawei of ebay for £20 & unlocked it and it's working just fine. Can't see much difference in speeds between the 2.
It's not like on ADSL where you needed to match the chipsets otherwise you lost maybe 2meg.
ryant704
Guru
Message 4 of 15
Some people say ECI work better if the cabs are ECI, not sure If It's the same for Huawei equipment. Could test this when I get my line finally fixed.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
chrcoluk
Message 5 of 15
my own experience is no change of sync speeds but matching them up seems to improve error rates.
I am on a ECI dslam and was given a HG modem, I got hold of a ECI modem and now have noticebly less packetloss on my tbb graph.  The sync speed is around the same.
In many cases in real terms there may well be no noticeable affect but in marginal cases the numbers of errors could affect DLM which in turn affects performance.
NewtronStar
Expert
Message 6 of 15
Just enjoy the experience of the HG612 unlocked you will not see much difference between ECI or HG612 modems
but you have the extra benefit with the HG612 to see your stats and see the wonders of FTTC and see how it works
and watch the attainable rate fall and rise over 24 hours, like the moon cycles over a month, and listen to a Jean Michelle Jarre track while doing so. Smiley Wink
popup
Message 7 of 15
Can someone please tell me how I can determine whether my DSLAM is ECI or Huawei?
ryant704
Guru
Message 8 of 15
Here is a picture of a ECI Cabinet
Huawei Cabinet below
popup
Message 9 of 15
I popped round the road to have a look and it looks like the Huawei one.
Apparantly, my stats can also show what I am on?
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
Bald_Eagle1
Message 10 of 15
That's a Huawei.
This is an ECI:-
US: (0,95) (880,1195) (1984,2771)
DS: (32,859) (1216,1959) (2792,4083)
