curiousfellow
Message 11 of 15
Re: New Install, Huawei DSLAM ECI Modem
IMO, you be better off ditching the HH3 for a simultaneous dual band router if you want to change any piece of the Infinity equipment.
john46
Message 12 of 15
the post is about which Modem to use with which cabinet nothing to do with routers /hubs
ryant704
Guru
Message 13 of 15
It's rumoured matching cabinets/modems are better as the firmware talks to each other, only rumours though.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
john46
Message 14 of 15
I have not seen any difference between the two to be honest i have the Huawei and my neighbour has an ECI
and there is no difference in IP Profile or speed like you posted Ryan it seems like a rumour
Bald_Eagle1
Message 15 of 15
FWIW, I have monitored quite a few connections using an ECI DSLAM with an unlocked HG612 modem.
Quite often (not always) the connections were still on fast path after being connected for a few weeks.
Most of them end up having Interleaving applied at a fairly low depth after a couple of days with the HG612 connected & thus sync speeds / IP Profile reduce & ping times increase.
Once monitoring has completed & the ECI modem reconnected, IP Profile, therefore sync speeds, increase again after a week or so.
We can only assume that is beacuse Interleaving etc. has been removed again.
The reverse MAY be true when connecting an ECI modem to a Huawei DSLAM, but as it is so hard to get any meaningful stats from an ECI modem, we just don't know for sure & I'm not aware of many people using ECI modems with Huawei DSLAMS to even get a decent volume of IP Profile data.
So maybe there is SOME truth in the suggestion that modems should be matched with DSLAMS wherever possible.
