Travelusa
Expert
Message 1 of 10
New Issues with Boadband
Got my line sorted out a month or so back after the Hub6a software update
my ip profile dropped from 76 mb to 10 mb
wholesale would not auto reset
so engineer called comfirmed the that line was ok and checked that 2244 was the leasted stable software
and got wholesale to reset also found that the new 5c faceplate replaced by the eng also had a impact on my line speed as it only increased from the 10 mb to only 45mb
removed the plate and went for a ord filter speed increase back to the 70 plus mb
been ok since ????? spoke to soon
the last 24 hrs the hub has been resiyncing and true to form the speed dropped to 3 mb
within the last hr it has resynced again and gone back up to 70 mb
how can the line do this when line tesst show no fault and i cannot hear no line noise
can this be a exchange broadband card fault and bt so no issues for broaband in the Area
I dont want to go though reporting again as it took over 2 months to get sorted out last time
never got any refund for the issues caused by there daff software issues
Any Good Ideas out there would be helpful
9 REPLIES 9
pippincp
Sage
Message 2 of 10
Re: New Issues with Boadband
Get a decent 3rd party router.
Travelusa
Expert
Message 3 of 10
Out of ones out there what would you suggest
The netgear one looks ok to me
So your saying its the hub6 again
Webby
Message 4 of 10
Billion 8800NL R2 is reasonably priced and gets good reviews.
Travelusa
Expert
Message 5 of 10
Well
Have given up with the hub 6a and gone back to hub5
the hub 6 started resyncing every half hour
the speed would drop then next time back up to full speed
Will start looking at the other routers soon
RogerB
Guru
Message 6 of 10
Good advice from Webby ... my billion came this afternoon, set it up just the once, synced up 4megs faster than the Hub6 and SNR is 6db both datastreams ... typical latency 27-30 millisecs. ... minimal INP no interleave latency. The only pain was setting my Chromecasts (2) up but sorted it. 😉
Webby
Message 7 of 10
I have a 7800DXL (ADSL only) at the moment but work begins on our cabinet tomorrow, according to roadworks.org so I'll be ordering the 8800NL soon 🙂
Travelusa
Expert
Message 8 of 10
Well
the old saying touch wood and whilstle
the hub5 has not resynced since installed
yeppie
whenyou get your new router can u give some updates on performance
Travelusa
Expert
Message 9 of 10
Well
11hrs on and no resync
so the software must have got corrupted in the Hub6a
RogerB
Guru
Message 10 of 10
Night time cometh ... beware the bogieman. See if it gets through the night, worst time. After that you need it to stay connected every night ... then you'll know it wasn't the line, but the hub for deffo.
