JohnW47
Message 1 of 3
New Laptop
Our existing Desktop is covered by Macafee. I would like to extend the cover to include a new Lap top. Can anyone advise on what steps I should take to achieve this? The lap top has a 90day Macafee cover. It talks OK to our BT Hub ( a white one) Someone suggested I should log into my BT Yahoo account. But then what?
Regards
2 REPLIES 2
monarchjock
Message 2 of 3
Re: New Laptop
Log into www.btinternet.com. Follow the My Account link then the BT Netprotect link. You will have to log in here with your btinternet credentials again. Just follow the instructions from there. If MacAfee on your desktop is not provided by BT then when it runs out you can do the same for it.
Distinguished Guru
Message 3 of 3
Re: New Laptop
Hi
If you do decide to install the BT version, note that the BT NetProtect Plus doesn't have all the features that the McAfee Security Suite provides.
(Thought I'd better include this so you wouldn't be disappointed).
Installing the BT Version will automatically remove the McAfee Version.
Also, have a read of the following as it tells how to get the BT version - http://bt.custhelp.com/app/answers/detail/a_id/12640/c/346,510,2164
Finally, this link shows you what to expect during the download of BTNP - http://bt.custhelp.com/app/answers/detail/a_id/14177/c/346,510,3998
-+-No longer a forum member-+-
