Rythium
Message 1 of 18
New Line - incredibly SLOW speeds! Help!
Hey guys, last week i had my new line installed to my house after 7 weeks of waiting for BT to actually successfully turn up at our house. However, after the 24h period - our connection is terrible. Here is the data i've collected:
Download Speed: (OOKla Speedtest) 25.67kilobytes per second.
Upload Speed: (OOKla Speedtest) 104.21kilboytes per second.
Here is the information on our ADSL connection: (From BTHUB3):
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 03:46:45
Downstream:2.679 Mbps
Upstream:798 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.5 dB / 5.9 dB
Line attenuation (Down/Up):46.4 dB / 27.3 dB
Output power (Down/Up):17.3 dBm / 12.6 dBm
FEC Events (Down/Up):162375 / 8314
CRC Events (Down/Up):5 / 9906
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):8 / 11848
Error Seconds (Local/Remote):5 / 987
As you can see from above, we should be recieveing around 2.5MBPS. Divided by 8 comes out to around 375Kilobytes. Our connection is currently 25Kilobytes. This has not increased since our line was installed. I've been on countless calls with BT and have done EVERY CHECK KNOWN TO MAN. It's been plugged into 3 ADSL ports, even the master sockets test socket. I've run the quiet line test, just to hear nothing on the phone line. Please help me sort this out? thanks.
edited: Also, our connection is very intermittent and continously drops. BT HAS told us there is NO FAULT with the line. And will charge us £130 if an engineer comes to 'fix' it.
Plus, i am a world of warcraft fan, and if you didnt know, Warlords of Draenor came out yesterday. I am suffering from withdrawal symptoms lol..
17 REPLIES 17
imjolly
Message 2 of 18
Re: New Line - incredibly SLOW speeds! Help!
can you go back to test socket please nd connect with new filter and then repost stats.  with your attenuation and a good line with no noise I would expect a connection speed of about 6/6.5mb
can you run btspeedtester and when first test completes then run diagnostic test and post results  should be done with wired conenction and don't reset before test
Rythium
Message 3 of 18
OKay, sure : here are the results
firstly, we've only got 1 microfilter.
here are the BTW Speed test results:
http://speedtest.btwholesale.com/
1. Best Effort Test: -provides background information.
 Download  Speed
 0.24 Mbps
0 Mbps0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.24 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.19 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.64 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.64Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
imjolly
Message 4 of 18
can you connect to test socket and repost the router stats please
problem is your profile is far to low for your conenction speed which is very unusual for 21CN connections.  I think your profile should be 2.36mb based on your conenctiion speed
Rythium
Message 5 of 18
Test Socket:
ADSL Line Status
Connection time:0 days, 00:25:01
Downstream:5.056 Mbps
Upstream:798 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.5 dB / 5.0 dB
Line attenuation (Down/Up):46.3 dB / 27.1 dB
Output power (Down/Up):20.1 dBm / 12.6 dBm
FEC Events (Down/Up):171 / 37
CRC Events (Down/Up):0 / 318
HEC Events (Down/Up):0 / 16
Error Seconds (Local/Remote):122 / 1007
imjolly
Message 6 of 18
thats more like it - 5mb connection speed.  there is a problem either with front platte of master or your extension wiring
what about btspeedtester diagnostic test again and see if that has helped
Rythium
Message 7 of 18
Why am i not recieveing the 5MB download speed though? mine is still at 25kb!
imjolly
Message 8 of 18
post btspeedtester results and if still same even with faster speed then get mods to help
Rythium
Message 9 of 18
yes, no change:
 Download  Speed
 0.17 Mbps
0 Mbps0.25 Mbps
 Download speedachieved during the test was - 0.17 Mbps
 Upload Speed
 0.66 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.66Mbps
Rythium
Message 10 of 18
I even found another microfilter, and it made no change
