flashman37
Newbie
Message 1 of 8
New Master socket
Hello,
Its my first posting so excuse if I'm being a total numpty
How do I arrange for a new master socket to be installed.
We have had the line in for some 30 years or so, and the wires are looking a bit shabby.  Since I have recently decorated, I would like the socket moved slightly too.
Any ideas ?  I have browsed the catalogue, and spoken to someone online, but it seems as the faulty line is the only route - although its old and tatty, Im not sure its actually faulty - although I wouldnt mind confirmation of that, if that could be achieved too 🙂
Pete
7 REPLIES 7
Message 2 of 8
Re: New Master socket
try quiet line test  dial 17070 option 2  should be quiet no hiss/crackle.  best done with corded phone  if cordless then dull hum normal
if this is ok then openreach won't replace your master or move it for free as - not broke don't fix it - openreach moto
flashman37
Newbie
Message 3 of 8
Thanks for the tip
Tried that - all ok , which is good in one sense, but obviously cannot go down that route 😞
I think I would still like it moved / updated
Any ideas of cost ?
Distinguished Guru
Message 4 of 8
Hi
It is about £130. Contact your comms provider. if BT Retail then call 0800 800 150 or 0330 123 4150 from a mobile.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
SpacedMan
Message 5 of 8
Why no move it yourself?
It's only 2 or 3 wires, write down which wire goes to which terminal so you don't get mixed up.
Master socket are available from DIY stores, around £10, as is the wire and a junction box to join the 2 cables, then just tack the wires round the skirting board with the correct tacks.
I moved mine years ago with no problems, the sockets even come with the tool to fit the wires to the terminals.
Distinguished Guru
Message 6 of 8
Moving an openreach socket would be in breach of your terms of service, it is not advisable to move it yourself.
Message 7 of 8
@spacedMan that is very bad advise and could cost the poster there service
rhyds
Expert
Message 8 of 8
Also, DIY shop master sockets are cheap rubbish. A proper BT/Openreach master socket has the test socket so you can isolate your own internal wiring.
