Message 1 of 12
New Modem Router
After Loosing all my hair in trying to get my AVM Fritz!Box 7390 Wroking stable I finially gave up and have now had it refunded.
Problems that i had with the Fritz!Box were as follows:
Poor Wifi (Worst Wifi I have ever used)
Kept dropping Connection (6 - 7 times a day)
Kept Restarting (3 - 5 Times a day)
My next option I believe is a Draytek 2850n which I think I should have purchased in the first place but saying that im wondering whats everyones views on the Draytek? has anyone used the 2850?
I have previously had a 2820n and that was the best device i ever used...
11 REPLIES 11
Message 2 of 12
Re: New Modem Router
OK after much reading around i think that i am going to take the plunge and get the 2850n
Will let you all know how it goes...
P.s. Where is the best place to buy this from? DABS are doing it for £202
Message 3 of 12
Just a little note, you will still need the Openreach modem, just make sure your new router supports WAN PPPoA
Message 4 of 12
As far as I am aware I can do away with the OR Modem as the Draytek has a built in VDSL Modem
Message 5 of 12
I am not aware of this. John46 do you know about this ?
Message 6 of 12
according to its tech spec yes you can
Expert
Message 7 of 12
Yes, the Draytek mentioned would replace both the Openreach modem and the Home Hub. Billion - and others I'm sure - also sells a modem/router that would replace both. The Billion 7800N that I have still needs the Openreach modem but has a EWAN port and works very well in place of the Home Hub.
Message 8 of 12
DrayTek 2850n
Hi
Does anyone have a Draytek 2850n or Vn? can anyone comment on the performance?
Message 9 of 12
Interesting - I hadn't thought about using an alternative to the HH. It's attractive to have 1 box rather than 2, and I strongly suspect the quality and performance of the Dratek will be better.
I see that shop.bt.com are advertising the 2850n for an equal best price.
Oops, just found the show-stopper:
"The Vigor 2850 is a variant of our Vigor 2830 series with the addition of an extra VDSL interface (for the BT Infinity™ service) for connectivity up to 50Mb/s."
Up to 50Mb/s is unacceptable with 80 anfaster just around the corner.
Message 10 of 12
I think you will find that is old copy as the 2850n supports 17a and 30a VDSL profiles which offer speeds up to 100Mb/s and 150 mb/s respectively.  I own the older 2750n which currently indicates a maximum speed of over 90Mb/s from 17a on my line. The spec can be found here.
