Message 11 of 32
Re: New Setup | Constant Disconnects and variable speeds
@imjolly  @Keith_Beddoe  @pippincp
Thanks for the clarity,
So,  I went round and opened faceplates of all extension sockets and the actual wiring connecting to the sockets has been cut clean and nothing is connected to them)
Nothing was connected to 2/5 on the master socket.
Only A / B   (solid orange/solid white)
So it looks like currently all I have is a working master socket, cable enters the property from underground, through a grey box, up our wall and directly into our Study / Computer Room into the master socket does not veer off to any other extensions.
Message 12 of 32
You will have to wait for the visit from Openreach, who will test the line.
Message 13 of 32
ok cheers, figured as much.
Thanks for taking the time to help though.
Message 14 of 32
@Keith_Beddoe  @imjolly  @pippincp
Just to update:
Engineer arrived this morning , went through his checks and his theory is that somewhere along the line between grey drop line box and master socket, there's an earthing issue with the Orange / White pair.
He's switched over the pairs so we're now running off Green / Black, switched the Master Socket to a upgraded VDSL socket.   He wasn't able to remotely request a DLM reset which I had to do via CS, obviously will recheck after the 10 days settling period but currently, all looks good
http://www.speedtest.btwholesale.com/
Download Speed (Mbps): 73.99
    Upload Speed (Mbps) : 19.72
Product code:Smart Hub 2
Serial number:+091298+1929005478
Firmware version:v0.16.02.08304-BT
Firmware updated:Sat Dec 21 15:42:23 2019
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,00 Hours07 Mins45 Secs
Data rate:20 Mbps / 79.987 Mbps
Maximum data rate:19.469 Mbps / 85.838 Mbps
Noise margin:4.3 / 7.6
Line attenuation:4.7 / 14.0
Signal attenuation:4.7 / 13.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:50.6 MB Uploaded  / 368.0 MB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-RWA8XW
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-RWA8XW
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:04:A2:22:94:24:6D
Software variant:-
Boot loader: 0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 15 of 32
Although saying that the BT Hub is reconnecting - has happened 3 times since typing that post in the past 10 mins.
EDIT:  BT Hub is in a state of reconnecting loop - I get about 30 secs of connectivity then connection drops.
Is that down to the DLM reset and line syncing again ?
(retested phone line and no static present)
Noise level has jumped up significantly and upload speed has halved.
Board version:R01
DSL uptime:0 days,00 Hours03 Mins10 Secs
Data rate:10.917 Mbps / 78.968 Mbps
Maximum data rate:22.218 Mbps / 86.355 Mbps
Noise margin:18.4 / 8.0
Line attenuation:4.6 / 14.2
Signal attenuation:4.3 / 13.5
VLAN id:101
Data sent / received:2.7 MB Uploaded  / 72.3 MB Downloaded
BT Wi-fi:Activated
Firewall:On
Software variant:-
DSL uptime:0 days,00 Hours04 Mins36 Secs
Data rate:14.255 Mbps / 79.987 Mbps
Maximum data rate:23.154 Mbps / 86.566 Mbps
Noise margin:15.0 / 7.9
Line attenuation:4.7 / 14.1
Signal attenuation:4.6 / 13.4
Message 16 of 32
CS won't do a DLM reset they will simply reset your connection just like you pressing reset button
if getting that many drops then I would try 1 factory reset of hub by pressing the recessed button on back and holding until lights flash
from the stats the resets so far have not had much affect on your connection speed
Message 17 of 32
@imjolly
CS requested the DLM reset from a specialist 'team'
After the 10 mins of constant disconnects the connection is holding stable now and has been for the past 3 hours, with the below speeds.   I'm fairly happy with it now and touch wood it holds moving forward, but will monitor over the next 10 days.
Thanks for all your input.
Board version:R01
DSL uptime:0 days,03 Hours21 Mins55 Secs
Maximum data rate:18.502 Mbps / 85.368 Mbps
Noise margin:10.4 / 7.4
Signal attenuation:4.6 / 13.5
VLAN id:101
Data sent / received:113.4 MB Uploaded  / 852.7 MB Downloaded
BT Wi-fi:Activated
Firewall:On
Software variant:-
Message 18 of 32
Stats look ok now so just a matter of keeping checking and hopefully it remains stable
it very unusual for CS to be able to organise a DLM reset they are more likely to just reset your connection
Message 19 of 32
@imjolly
The chap in CS said he couldn't do the DLM reset but would request it from the department that could.
In relation to this, he stated there would be a 10 day stablisation period again but didn't mention anything about the hub reconnecting during this period,  would the DLM Reset cause the hub to disconnect infrequently during this period?
Or is there still a possible underlaying issue?
The speeds I'm getting are fine now and I'm happy to run with them but the random disconnects are still somewhat infuriating,  I stream and record gaming content so having the random drops are killing my schedule and live content.
Message 20 of 32
I still don't think CS organised a DLM reset but in any case your line should be stable with no random drops  the drops in connection suggest you still have a line problem
