Message 11 of 11
Re: New Speed worse up-time
This is the last 'reboot' cycle I could see:
19:12:23, 22 Jun.ath10: STA a0:0b:ba:82:37:c8 IEEE 802.11: Client disassociated
19:12:22, 22 Jun.( 148.960000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:12:22, 22 Jun.( 148.950000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
19:12:11, 22 Jun.( 137.880000) WAN operating mode is VDSL
19:12:11, 22 Jun.( 137.880000) Last WAN operating mode was VDSL
19:12:10, 22 Jun.( 136.400000) PPP IPCP Receive Configuration ACK
19:12:10, 22 Jun.( 136.390000) PPP IPCP Send Configuration Request
19:12:10, 22 Jun.( 136.380000) PPP IPCP Receive Configuration NAK
19:12:10, 22 Jun.( 136.380000) PPP IPCP Send Configuration ACK
19:12:10, 22 Jun.( 136.380000) PPP IPCP Receive Configuration Request
19:12:10, 22 Jun.( 136.370000) PPP IPCP Send Configuration Request
19:12:09, 22 Jun.( 135.070000) PPPoE is up -​ Down Rate=46901000Kbps, Up Rate=9999000Kbps; SNR Margin Down=13.1dB, Up=14.5dB
19:12:09, 22 Jun.( 135.050000) CHAP authentication successful
19:12:08, 22 Jun.( 134.900000) CHAP Receive Challenge
19:12:08, 22 Jun.( 134.900000) Starting CHAP authentication with peer
19:12:08, 22 Jun.( 134.900000) PPP LCP Receive Configuration ACK
19:12:08, 22 Jun.( 134.890000) PPP LCP Send Configuration Request
19:12:08, 22 Jun.( 134.890000) PPP LCP Receive Configuration Reject
19:12:08, 22 Jun.( 134.870000) PPP LCP Send Configuration ACK
19:12:08, 22 Jun.( 134.870000) PPP LCP Receive Configuration Request
19:12:08, 22 Jun.( 134.870000) PPP LCP Send Configuration Request
19:11:28, 22 Jun.( 94.770000) Admin login successful by 192.168.1.68 on HTTP
19:11:27, 22 Jun.OUT: BLOCK [15] Default policy (ICMP Packet is not a request packet: ICMPv6 type 143 code 0 fe80:0000:0000:0000:ca91:f9ff:fe1c:43e1-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ptm0)
19:11:25, 22 Jun.OUT: BLOCK [15] Default policy (ICMP Packet is not a request packet: ICMPv6 type 143 code 0 fe80:0000:0000:0000:ca91:f9ff:fe1c:43e1-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ptm0.101)
19:11:24, 22 Jun.( 90.130000) CWMP: session closed due to error: No response
